TV cable problem? or did somtin jus decided b a PITA
Old Apr 10, 2002 | 03:45 PM
XxMoLexX's Avatar
im no expert on tranny's at all.. i did a fluid and filter change bout 2 weeks ago.. and as of late my shifter has gotten real "playful".. meaning when its in gear there is alot of play within it... the stick physically moves id say 1/4 to 1/2 inch but will stay in Driver or reverse or wateva its in... now when its in park it seems like there is somtin pullin it back so as soon as i push the button its almost immediatly goes into reverse...
is this a TV cable problem?
its a 700r4 auto (Duh)
Old Apr 11, 2002 | 01:54 PM
XxMoLexX's Avatar
bttt
Old Apr 11, 2002 | 08:21 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Down by the trans on the cable there is a metal bracket that holds the cable to the trans. Make sure this is connected to the trans, (you have to take it off when you remove the trans pan to drain the oil). If not this will do the problems that you describe.
Old Apr 11, 2002 | 08:42 PM
XxMoLexX's Avatar
yea i remember that .. i made sure i put it on there in the right spot and made sure it was snug.. but ill double check anyways..
tonight i realized that im never really shifting into 4th or OD whicheva u wanna call it... i doesnt seem to leave 3rd.. even when i manually shift it... its as if ive lost 4th... and now when i put it in park.. the car wont stay still if not perfectly level spot.. i have to use the emergency brake...
this still the same problem?,.. im gonna hae to fix it 2morow.. but i need to kno wat to do
Old Apr 14, 2002 | 05:37 PM
360Iroc's Avatar
thats sounds like a problem that i had, when you took your pan off you took off you shift linkage. when i replaced mine it was a little off and it would not go into park. you should adjust it forward so it goes into park correctly. as for the shifting check the tv cable, you may need to reset it. to do this you push the clip on it i believe and pull it towards the back of the vehicle, then back to it original position and it will reset itself...
good luck
Ghettobird52
Jul 5, 2024 11:18 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
