Gears...
Old Apr 11, 2002 | 12:19 PM
Greg Kuhlmann's Avatar
Gears...
My 87 TA with the lg4 has the stock 2.73 rear end.
I was looking in the summit magizine today... they have new gears for around 200 bucks.
What kind of rear end do i have is it 10 bolt 12 bolt or what?
I've heard that you need to match the rear end with the cam you have... with a new motor my cam is going to be a 4.88 intake and 4.8X exhuast... how do i match the rear end with the cam... i was looking at some 3.42's.... any help would be nice!
Old Apr 11, 2002 | 12:48 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Re: Gears...
You're right about matching the gears, I don't know too much about cams, but will your stock heads handle that much lift? If they do, 3:73s will probably help you more in the 1/4.
Also you'll need to buy an intall kit with it about another $100.
Old Apr 11, 2002 | 09:00 PM
no no.... I have a 350 block that ive been building, keith black .100" dome pistons with the holley systemMAX II set which is cam, heads, intake manifold... so how do i match the cam to the gears?
Old Apr 11, 2002 | 10:44 PM
Car: 99 Formula
Axle/Gears: 342
I'm not sure of the power band of that cam, but say the cam/intake stop making power at 6,000 rpms, well if you're concerned about 1/4 then you wouldn't want to pick gears like 4:56s that would make you run past your power band before the finish line. You want your gears to keep you in your powerband, so first figure at what rpm your car stops producing power and go from there. Also a TC also plays a role in selecting a cam too.
WTR388
Jun 14, 2015 09:40 PM
90caddy
Carburetors
Nov 5, 2013 01:55 PM
Bullydawg
Dec 12, 2008 07:04 AM
JerseyMark
Jan 3, 2007 10:46 PM
MrDude_1
Oct 20, 2006 01:42 PM
