T5 & 3.23 gears... What speedo gears do I need?
Old Jan 2, 2007 | 08:29 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey everyone,
I have been searching for about 45min now..And I found plenty of info for 700R4's and T5's w/3.73 gears... but nothing for my set-up. I have 3.23 gears in my car and I am installing a T5 from a car with 3.08's. What gear(s) do I need to replace & what gear should I replace it with? According to our Tech Info pages... 87 Cars with the LG4 V8 & a T5 came with 3.23's, so I know the magic combonation has to be out there somewhere.
Thanks in Advance,
Mark B
Old Jan 2, 2007 | 08:40 PM
IIRC it's 7 blue & 19 white. For stockish tire diameter of around 26", that is.
Old Jan 2, 2007 | 08:41 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
7 tooth drive
18 tooth driven (discontinued)
Those are what came stock on the 1987 t5 3.23 camaros
Old Jan 2, 2007 | 08:57 PM
JerseyMark's Avatar
Engine: 96 LT1
Do you guys know what might be in the trans right now? It was setup for a 3.08 gear. I did some math on a napkin in front of me and the only combonation that would make sense is:
3.08 Gear = 9 Tooth Drive & 22 Tooth Driven
3.23 Gear = 7 Tooth Drive & 18 Tooth Driven.
That would give me about a 5% difference which is what I need. Therefore I need to replace BOTH of the gears. Does that sound right?
Old Jan 2, 2007 | 09:19 PM
9 tooth drive (red)
22tooth driven (green)
Old Jan 2, 2007 | 09:21 PM
Something else.
Probably 8 teeth and something else driven.
Speedo gears aren't so hard. Think about it...
How does the odometer work? 3 seconds....
It's a turns counter.
1000 turns of the cable = 1 mile. That's the magic constant that works ALL cable speedos.
All you gotta do, is calculate how many times your drive shaft turns in one mile, and then, your "correct" speedo gear (regardless of what "came" in any of them) is the driven-to-drive ratio that make the cable spin as close as possible to 1000 times in 1 mile.
It's just a car, it's not brain surgery or something tough like that.
Old Jan 2, 2007 | 09:29 PM
JerseyMark's Avatar
Engine: 96 LT1
Thanks Guys... Now i know what I need... All I have to do is find it. haha
Old Jan 2, 2007 | 09:52 PM
8 teeth driven (Black)
20 teeth drive (blue w/ plastic shaft)
would also work, but you can't get an 8 tooth except for the 28 spline (ford) output shaft. The GM output shaft is 27 spline. You could probably do some fancy machining to make it work, but I'd just try to get that 18 tooth drive gear... and if you find a place to get them, pick one up for ME, thanks.
you can get mechanical speedo (driven) gears for muncie trannies that will work, but I'm guessing youre using an electronic VSS in your 91.
I've been to all of the local car dealers trying to get the same stuff for my car since I switched to 3.23's with my 92 RS T5
Old Jan 2, 2007 | 09:59 PM
L.I.N.Y.92CAMARO's Avatar
What would it be if your were using a T-5 With 4.10's and roughly a 28" Tire In the back? And The Same set-up but with a 26" Tire out back?
Thanks,
Old Jan 2, 2007 | 11:10 PM
with 4.10 gears
and 28" tires:
7 tooth drive
24 tooth driven (I don't even know if this exists though, maybe for a muncie mechanical speedometer)
26" tires: (both are easy to get)
7 tooth drive
22 tooth driven
Old Jan 3, 2007 | 04:25 AM
Pat Hall's Avatar
Originally Posted by ttypecamaro
7 tooth drive
The above combo is the correct baseline speedo gears for a T5 w/3.23 rearend gears.
Old Jan 3, 2007 | 05:48 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Old Jan 3, 2007 | 04:47 PM
i thought it would be the other way around with 26" tires it would be roughly 24 driven and with 28" tires it would be 22 Driven.
I dont have to change the Drive gear at all? Just the Driven gear?
Can someone verify this and are those the correct gears I would need For that set-up i listed?
Thank You,
Old Jan 3, 2007 | 05:33 PM
JerseyMark's Avatar
Engine: 96 LT1
Lets see if I can get lazy...Does a 23 tooth driven gear exist? Combined with the 9 tooth drive gear I aleady have.... My Speedo will only be off 1%. I can handle that. So at 100mph, my speedo is going to read 101mph.
Old Jan 3, 2007 | 07:39 PM
23 driven exists in a mechanical speedo. If you wanted to carve a "D" shaped hole in the gear you could HOPE it works.
Old Jan 3, 2007 | 08:28 PM
JamesC's Avatar
General info:
https://www.thirdgen.org/forums/tran...en+gear+sleeve
JamesC
Old Jan 3, 2007 | 10:46 PM
Mdenz3's Avatar
Car: 91 RS
Axle/Gears: 3.42 LSD
This place sells almost any speedo gear you could want.
http://www.transmissioncenter.net/sp...n_______va.htm
GTAman
Jul 3, 2024 07:29 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
88rscamar0
Sep 23, 2015 09:08 PM
andy74
Sep 3, 2015 08:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
