Difference between 7.5 and 7.625 ring gears
Old Apr 11, 2002 | 12:46 PM
jeffs82z28's Avatar
Would somebody please tell me if I can install a 3.42:1 ratio 7.625" ring and pinion set onto a 7.5" limited slip carrier that now has a 3.23:1 gear set?
I can get the 3.42 for cheap cheap, and couldn't find any answers, so I thought I'd throw it on the board.
Old Apr 11, 2002 | 05:12 PM
Jay 727's Avatar
Re: Difference between 7.5 and 7.625 ring gears
Yes you can.
Old Apr 11, 2002 | 09:06 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
They'll both fit on the same size carrier. GM only increased the size of the ring gear slightly. Nothing else changed.
Old Apr 11, 2002 | 11:55 PM
jeffs82z28's Avatar
Fantastic:rockon:
I thought it was that way from checking catalogs and what
other info I could find, but I wanted a definite answer before
I started the project.
Thank you very much for the help
Jeff
Old Apr 12, 2002 | 03:43 AM
Quadrabog's Avatar
Car: '86 Monte Carlo SS
second shift blows
Try third shift.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
Dialed_In
Aug 20, 2015 01:45 PM
