Can I use a T10 from an 82 camaro 4 cylinder???
Old Apr 14, 2002 | 12:31 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I found a borg warner T10 at the junk yard in an 82 camaro 2.5L four cylinder. It has the driveshaft, but no crossmember. Can I use this behind a 400? If so, could I use a old style bellhousing to take a 168 tooth 14" flywheel that is designed for a 400? Also, it the torque arm the same as my 700R4 one?
I need info fast, I want to get this tranny today if I can use it.
Old Apr 14, 2002 | 05:21 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Come one guys, someone has to know. Heres an update.
I found out that the T10 for the V8 and L4 both have a 10 spline input shaft. Also, the 82 camaro I found with the T10 has a Z-bar clutch. Its freakign weird. But then I found another 84 camaro with a T10 and a four banger and it has a hydraulic clutch, in fact the exact same hydraulic system as a T5. I really need to know if I can use this tranny behind a 400 because this one has everything - cross member, driveshaft, shifter, everything.
Old Apr 15, 2002 | 02:55 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
btt
db057
Aug 22, 2015 08:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
beachrodder
Aug 7, 2015 04:27 PM
