throtle body coolant bypass?
Old May 5, 2002 | 03:52 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
I can assume most of you have unhooked and bypassed this part on your thirdgen???
Old May 5, 2002 | 04:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, bypassed since '97, no problems.
DAMMIT I want to be outside and working on my car!! Not stuck inside doing HW! (sigh) One more week; one more week....
Old May 6, 2002 | 11:32 AM
Guest
Posts: n/a
well good, i knew that was dumb. why oh why send all the extra heat up there?
do they make plenium spacers for our car???
I migh just make some anyways.
I know a big drag racer trick is to use plywood carb spacers, cause they carry no heat what so ever, but only last a few passes cause they soak up gas.
but with our system it is only air, so some plywood spacers covered in some silicone should really keep the upper plenium temp down.
it gets too hot too fast.
Old May 6, 2002 | 01:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
One theory is that it helped the car warm up faster. Another one is that it prevented the TB blade from freezing in cold weather... but I'm in NJ, with cold weather every winter, and I've never had it freeze up. Hell, engine heat alone would unfreeze it. It doesn't lower emissions, either. 'Fact, if I recall correctly, the 4th gen 3.8 and 5.7 f-bodies don't have any TB coolant lines.
Old May 9, 2002 | 10:36 PM
OnixV6's Avatar
just an FYI, 4th gen 5.7L F-bodies DO have TB coolant lines and the 4th gen 3.8L flows coolant to the TB from the block via the intake manifold.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Kenwood
Sep 4, 2015 05:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
