Accel coil owners, or other hi out put coils.
Old May 3, 2002 | 08:20 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
Ok you know on the coil it is round with a square of metal around it. go out and start your car in the dark and look at your coil.
inside that square piece, it look like its hollow inside, but I can see blue light glowing from inside there, and as i rev the engine it glows more.
also I could hear a ticking over there which is the sprk leaking from the round part of the coil the the square piece,
now with my EGR problems gone the car run fine but I am leaking spark. and it could of been doing that forever.
is mine leaking or are they all like this.
if its dark, run out n check, let me know plz.
its not leaking and jumpingto any part of the car or engine just from the round part to the square of metal that goes around it, but inside that square, so it is hard to see it but the glow.
Old May 3, 2002 | 09:06 PM
BitchinRS's Avatar
nope mine dosen't di it. Ihave all ways heard that the glow is a sign that the coil is going bad.
Old May 3, 2002 | 11:10 PM
Guest
Posts: n/a
Thats just wrong they should last forever, well kinda.
Could mean I got a problem else where, coil has so much juice and the car is not sucking it up. so it is now finding an easier way out.
anyone even use any dual core wire
8mm wires, hotshots i think?
8.5mm 9mm???
Old May 3, 2002 | 11:33 PM
WaynesRS's Avatar
8.5mm 9mm???
Well , I think it depends on how much you drive it and weather conditions . For ex - I drive to school which is an hour away . The weather down here is REALLY humid alot , even in the winter sometimes . In the summer its just FREAKIN HOT down here . Highs usually 95-98 . I don't expect my coil to last forever with these conditions of 1. driving for longer periods of time for two hours a day . 2. driving for longer periods of time for two hours a day WITH these HOT weather conditions . and 3.Just driving around in the summer for work or wherever with these FREAKIN HOT weather .
Now if your driving for a total of an hour and a half a day mid to light driving , it should last a long time ! ....Thats interesting about your coil though , I will have to check mine !
Also , where the coil is located , is REALLY a sucky place for it .No pun intended , well the pun is on GM for placing in there .The heat and vibration from the motor ! I had a new coil mounted in that spot before that only lasted a year ! I mounted my MSD gm blaster on the firewall .I just took a chance of hitting something in the wall , lol guess that wasn't to smart . I dont know there may not be anything behind it where I put mine .
Old May 4, 2002 | 11:04 PM
BitchinRS's Avatar
Wayne,
That not to bad. Here in Modesto CA the avarage summer time temp is 110*. You get used to it though.
Old May 4, 2002 | 11:30 PM
WaynesRS's Avatar
damn , not bad compared to Modesto huh ? ...Im pretty much use to it down here , sometimes it does kinda get to ya though .Do you live in the desert or is it just freakin hot there ? Summer before last , we had some days for a couple of weeks where the high was 100 .But not 110 !
Old May 5, 2002 | 04:22 PM
Guest
Posts: n/a
well the coil going bad could be my fault, closer inspection the 8mm wires i thought i bought are really 7mm wires.
I notice this when i was shortening my coil wire, it was tooo long about 5 inches too long.
Old May 5, 2002 | 08:10 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
I'll bet the humidity in Modesto is much lower than Baton Rouge!
I live in Savannah, which is a 98 degree 98 percent humidity steambath from April to September, much like Baton Rouge (I have been to the Bayou!) as far as weather goes.
My brother lives in Tucson, AZ where it is frequently over 110 degrees, but he tells me it FEELS hotter in Savannah due to the humidity.
Eric
Old May 5, 2002 | 10:30 PM
WaynesRS's Avatar
possible , Ive heard of melting plugwires with higher power coils , but not that ...I dunno , just make sure to get the right wires this time !! lol ...j/k .....But seriously , put some 8mm on there bro .
Old May 5, 2002 | 10:36 PM
WaynesRS's Avatar
Eric
man , I can't tell you how many days in the summer I wake up , hear the weather report "humidity 100% today " Im use to it ,
I just eat my crawfish , fish some , and enjoy these southern women !
Old May 6, 2002 | 02:13 PM
BitchinRS's Avatar
It depends on the day! Last forth of july it was so humid I thought I was go to have to swim through the air. Regular humidity in the summer around here is between 65% and 95%. I don't buy the "it feels hoter the more humid it is". The dry heat just kills me!!!! That could be becuase I used to spend a lot of time in upstate New York in the summer and I got used to the humidity. If you happen to get a slight breez it feels so good when it is humid. The wind in a dry heat is like an oven!!!!!!!!!!!
Old May 6, 2002 | 02:20 PM
Xenodrgn's Avatar
86 ramair, I own an Accel coil, stock mounting point and I have the same blue glow!!!
I'm so happy you bring this up, I just noticed it about a week and a half ago and it's good to know I'm not alone.
I'm going to get an MSD remote mount coil and a 6A box for my birthday, hopefully that'll fix me up good.
Old May 9, 2002 | 10:26 PM
WaynesRS's Avatar
I have an MSD coil , and have the glow now guys , thats why Im having car trouble ! except mine is doing it bad .
Old May 9, 2002 | 10:56 PM
KED85's Avatar
The factory coil in my 1985 S-10 Blazer is still good.
211,500 miles.
I used an Accel coil in that truck for 130K (of those 211,500) also.
The coil in my Firebird is an Accel.
I just came from back outside.
No, mine doesn't glow.
I also do not have my coil mounted over the exhaust.
If it's bad, return it for a free one from Accel.
Contact Mr Gasket tech for the way to exchange it.
Accel exchanges their stuff.
These cars run fine with 7mm wires, too.
eightsixseven
Dec 16, 2024 01:50 PM
tazs2000
Jul 15, 2017 08:44 AM
87 camaro iroc
Aug 20, 2015 07:47 AM
92camaroJoe
Aug 13, 2015 06:07 AM
