Anyone have a 3.1 Camaro w/ Iroc Dual Foglight Intake?
Old May 5, 2002 | 08:34 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
I wanna know how this is done if it is possible, i know i already asked but i dont wanna mess anything up when doin it. Thankx
Old May 5, 2002 | 09:27 PM
92Blue3.1's Avatar
i do, i got a tpi dual snorkel on eba for $19.00. then i cut off the the bottom of the lower part of the air box. one thing dont make the ram aor behind the foglights. it cuts airflow to the radiator . i had it and it would make my temps sky rocket. i took al the tubing off and left the 2 K&N's exposed to the cold air that hit the radiator. i acutally had a better gain with tubing off. but the hardest part for me was cutting the lower air box. it was a real pita. you will notice a good gain. mine shift'd at like 5250 when i floored and after that it was like 5500. it was well worth the time.Good Luck
Old May 6, 2002 | 10:06 PM
and this setup offers as much protection from dirt and water as the stock?
Old May 7, 2002 | 05:02 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
really good mod
you will need to fabricate a pipe though to be placed where the TPI or 2.8 would have had its MAF sensor
i made one out of tin and duct tape
it doesnt look too pretty, but it gets the job done
Old May 7, 2002 | 04:06 PM
92Blue3.1's Avatar
mine came with an MAF. so i have just removed the screen and just left it on there until i get my lazy but to home depot to get stuff to make my own.i have had no troube with dirt or water ive checked the filters and they were not wet or coverred with dirt. also u said u live in the outskirts of philly. i live in West chester PA which is not that far from philly. so get urself a tpi air cleaner and 2 k&ns and u should be fine.
Old May 8, 2002 | 09:06 AM
Thats cool blue I live in broomall, next time im in west chester i'll look for ya!
Old May 8, 2002 | 09:09 AM
And what is a MAF? Is it the plug in the stock crappy air cleaner? I was wondering about that, I took out the sensor for the stock air cleaner once, and my engine shook like a mother. If I was to get this, which I will, where will I put this thing to keep it working right? Please help all that can do.
Old May 8, 2002 | 03:05 PM
92Blue3.1's Avatar
no thats the IAT sensor.An MAF is on the 2.8 you dont have one so dont worry about it. if u get a tpi dual snorkel then it has a sensor built into the box. all u have to do is splice the wire and make an extention. i have no done this yet. my is still plugged in to the old air box. im not sure if they make a connector or not. oh and my grandparent used to live in broomall but they moved last month. they lived on 221 Parkview ave. anyways good luck
Old May 8, 2002 | 03:44 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Like Blue said, I wouldn't ram the air cuase the radiator needs to share that air too. just cut the bottom of the air box and leave the K&Ns exposed. Water and dirt shouldn't be a problem.
On a side note, You should consider to build a custom CAI (Cold Air Intake) down the road, cuase the stock snorkel is way restictive, just look at the curves that air has to make. By custom tubing a Conical K&N Filter as far from the engine as possible and placeing a box around it. Then drill holes for outside "COLD" air to get in, then the air coming into the engine is much cooler, flows in faster, makes an awsome sound, and most important. you get more horsepower. The colder the air, the more horsepower you cn make.
Just my .02
Old May 9, 2002 | 07:03 PM
RealDeal's Avatar
hey, since basically everyone seems to believe that cutting the bottom's of the boxes off is a better approach, would it be ok, to just buy the top portion of the snorkel.... or would that mean that there would be no place to mount the air filters? i've never actually gotten to look under the hood of a v8 so i don't know. i want to do this, to my '91 so if i get a reply soon enough (tonight) then i'll get one from ebay.
and one other question about CIA. would it be possible and efficient to use the dual snorkel to make two pathways for cold air (double the air)? one on the left side one on the right..... actually now that i'm thinking about it the battery might get in the way..... hmm... well, thanks for the help.
Old May 9, 2002 | 08:49 PM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
you are going to need the air box and the snorkel. You basicly only cut the air box in half. You need the air box to hold the filters in place and to bolt down the snorkel to get a good seal after the filters, cuase if air got in AFTER the filter, that would take away from the whole point of have the filter in the first place, you dont want dirt or water in the TB...
Old May 9, 2002 | 09:27 PM
RealDeal's Avatar
appreciate it. (4 minutes left to go in the auction, too, lol)
Old May 10, 2002 | 08:45 AM
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Did you get it?
Old May 10, 2002 | 04:56 PM
RealDeal's Avatar
nope... it ended up being around $30 and i know i can get it for much cheaper than that. thanks for getting back to me in time though
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Night rider327
Oct 9, 2015 09:25 AM
bjpotter
Oct 2, 2015 09:12 AM
meeklay812
Oct 1, 2015 03:46 PM
