Possible bad injectors?What size in 2.8?
Old May 9, 2002 | 09:17 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I think I may have a bad injector or two, and was curious what their lb/hr rating is. Anyone know of other GM(or even Ford)vehicles (other than 2.8 F-bodies) that use the same size injector? We might try a set from Pull-A-Part first before spending the $$$ on a new set. The engine has a few mods, but I doubt it needs a larger injector. I'm thinking probably around 19lbs/hr??? Anyone?
BTW, there is a fairly strong fuel smell in the oil (checked the dipstick)...the injectors were replaced about 3 years ago with new GM ones, does anyone think this could be caused by bad injectors or something else? Bad fuel pressure regulator maybe?
Old May 9, 2002 | 10:33 PM
WaynesRS's Avatar
Well , its possible they could be bad . BUT , highly unlikey . a bad fuel pressure regulater can do that . And usually , I think it is one or two injectors which people think are bad when actually its a bad fuel pressure regulator .
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Bryan F
Aug 18, 2015 02:28 PM
knight72
Aug 10, 2015 09:32 PM
