3.1 guys....MPH vs. RPM
Old May 14, 2002 | 08:01 AM
SAEspinz80's Avatar
Hey guys, I need your help with this easy little task. Next time you are on the highway...take a look at your speedo and your tach. and let me know how fast you are going at 2000 rpm's and 3000 rpm's in MPH while you are in OD.
I am trying to figure out if my rearend is stock or not. Or if there may be a problem with my car. For me @:
2000 RPMs = 50 mph
3000 RPMs = 80 mph
Let me know....thanks!
Old May 14, 2002 | 08:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could always pop the cover and check the gears themselves; have you changed the fluid yet?
Old May 14, 2002 | 09:43 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
2000 in OD= 60 mph
3000 in 3rd= approx. 90-100 mph
You don't look stock. I can hit 80 mph at 2500 rpm.
Old May 14, 2002 | 11:25 AM
SAEspinz80's Avatar
TomP, yea a friend of mine and I were talking this weekend about it, and he was like "you could always count the teeth". So I figure that was a good idea, because no I haven't changed the fluid yet. Thanks for the info though.
How do gears work....ie, if they were 3.23's would there be 323 teeth....etc. I don't know very much about gears.
Old May 14, 2002 | 01:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Lets take, for instance, my poor 3.73 rear with the blown posi that's sitting in the backyard. Count the # of teeth on the ring gear... my ring gear has 41 teeth. Count the # of teeth on the pinion gear, it has 11. Divide: 41 / 11 = 3.72727272 = 3.73.
The gears in that axle even say "GM 3.73:1" on 'em. I don't remember if my 3.42 axle gears say that.
Old May 14, 2002 | 07:17 PM
92RSMuscle's Avatar
1750 @ 60 mph
3000 @ about 100
Elephantismo
Feb 13, 2019 12:51 AM
Giocio
Oct 1, 2015 12:20 PM
cking99
Sep 22, 2015 11:33 AM
wisemanz28
Sep 20, 2015 01:26 PM
