Guess what I just found out! GM Service Bulletin for false MAF codes in '85!!!
Old May 22, 2002 | 09:22 AM
Xenodrgn's Avatar
Well, I guess that's it. It's very possible that this is my problem, I'm sure you've all heard about my intermittent code 34 (which has not reoccured in a while...)
I eventually traced the problem to the MAF sensor not getting enough voltage from circut 13 (or was it 18... ??), the wire that goes from the guages fuse to inside the engine compartment... The signal wire tested out and so did the grounds, that does not however rule out a bad ecm...
Should I buy a new ECM and a fastchip?
Old May 22, 2002 | 10:03 AM
KED85's Avatar
Truth?
Buy a ECM.
Find one from any 1985 Car, REUSE YOUR ORIGINAL CHIP.
Pull your electronic and throughly rebuild.
I swapped ina 1985 Corvette ECm into my Firebird.
Same thing.
Used old PROM, works perfect.
Rebuild your electronis including new timing chain swap.
Better results, promise.
More effort, yes.
Old May 22, 2002 | 01:49 PM
Xenodrgn's Avatar
I'm sorry, I should have specified...
The problem that was fixed with the onset of this ervice bulletin was a problem in the 1985 prom for these cars. It produced some wierd stuff...
Since I also think the ECM could be toast, I was going to buy a new one of them also. Since I need the new chip, and GM won't warantee the replacement of my prom (not a safety warrentee, doesn't carry over to new owner) figured I'd just get a Fast Chip while I was at it.
Get it now?
Old May 22, 2002 | 06:30 PM
KED85's Avatar
Great way to get the same results!
How much for those old chips?
They gotta be "leftover" items by now.
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
chazman
Aug 22, 2015 02:01 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
