stupied car
Old May 23, 2002 | 11:16 PM
theladiesman02's Avatar
stupied car
well i have an 88 camaro and i have incounterd my first problem but before i take it to the shop i would ask the experts
ok my car smells like gas
i dont noe wats wrong
the seals look ok
i just bought i new factory gas cap i need some help
like when you are driving you just smell the gas fumes
and when the car is in the garage it just smells like gas
(please let the problem be inexpensive)
Old May 24, 2002 | 12:39 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I think there was a recall with some of the gas tanks getting small pinholes in them im not 100% sure tho
Old May 24, 2002 | 09:52 AM
KED85's Avatar
This one is so easy for ya!
Open hood aftter you notice the "gas fumes".
Do you see anything?
Next after you drive, smelling fumes, park it, over a piece of cardboard to find ANY LEAKS.
Go have coffe, leave it overnight, your call.
Next time you drive, roll backwards, check drips, etc.
Oil leaks are as you suspect, dark, greasy.
Gas will dry, to a visible ring on the cardboard.
Find that/those answers, say hello again.
Gas cap, only you know if it's working right or not.
BUT REAL EASY TEST
Go to a FRIENDLY smog station.
Give them the GAS CAP, have them test it.
IF you by the Beaches of LA Area, I have a smog place that will do test for ya for free.
He's in Santa Monica.
Don't laugh, gas cap can fail & produce fume smells.
I really doubt you have a "leak" or else you'd see that gas puddle by now or be up in smoke!
Gvie those a try, yeah it's effort, but, you'll have better clues for price of a trip to smog place & free left over cardboard.
Where can it leak
Obvioulsy under hood/engine, back by gas filler neck area.
Gas lines go thru driver side of car (under the car)
Gas line under hood, driver side by power steering area.
It's one of those thick dark hoses, but goes top of engine.
Drive, make car smell, pull over, examine.
Don't use a match for seeing better if you try this at night time. J/K
Good for you to research a reason/cause before giving up your hard earned $$ for no true problem!
Old May 24, 2002 | 05:08 PM
i think u might be right about the gas cap expect for i just boughht a new one but i will go check to make sure like u said thanks guys
Old May 25, 2002 | 07:37 AM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
check the filter on the bottom of the purge valve cannister, propally really dirty like mine was. I had to replace the cannister, but no more feul smell for me. Also after you run the car for a while, feel the top of the "COntrol Valve" on top of the canister, it should be cold, not hot. If it is hot, replace the canister. I got mine for $115 at a chevy dealer. This canister stores all the feul vaper, and if you smell gas, so i've been told, this should be the first place you look. Hope that helps.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
