Okay guys don't laugh!
Old May 29, 2002 | 06:13 PM
Akshay's Avatar
My horn doesn't work.
But, I can't seem to find the horn.
Akshay
1989 camaro RS 2.8 5-spd
Old May 29, 2002 | 07:52 PM
dsaint1347's Avatar
I have a 1990 and it's located in the drivers side fender. From inside the engine compartment behind the battery I can see the horns. Just make sure all your connections are on a your horn fuse is not blown.
Old May 30, 2002 | 12:42 AM
Akshay's Avatar
Yikes, my battery is on the passengers side.
Akshay
1989 2.8 5-spd.
Old May 30, 2002 | 02:26 AM
KED85's Avatar
No biggie.
It's in there the driver side inner fender area, front.
Just bend your neck more and use a flash light to "see" them.
IF your "horn works" you'll hear a "click" sound upon button applying action.
IF no clicking sound (like a relay open & close), blown fuse.
BUT why blown fuse is the question?
Playing with wires up front lately?
Old May 30, 2002 | 11:20 AM
Akshay's Avatar
Originally posted by KED85
No biggie.
Nope, I bought the car 6-months ago and this is how it was.
Actually, the Courtesy fuse keeps blowing as well (cigar lighter, dome/map light, and horn doesn't work).
Akshay
1989 RS 2.8 5-spd.
Old May 30, 2002 | 02:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Make sure there's no change in the cigarette lighter hole...
On my car, the green horn wire (by the front of the inside front fender, driver's side) was bare, by the framerail. I wrapped it with electrical tape to prevent a short. Maybe the short is happening in the same spot on your car.
Old May 30, 2002 | 11:01 PM
KED85's Avatar
Try loose nuts or paperclips, too!
FOR REAL!
You found the problem.
Old May 31, 2002 | 07:55 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
What about the horn contacts? Take your horn button off to see if they are there. I still have to make me some new ones so i can have a completly functiional horn.
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
tero
Aug 6, 2015 06:34 PM
