found a gta
Old Jun 5, 2002 | 07:01 PM
wrstdude's Avatar
Car: '04 Rubicon
found a gta
I know this isn't V-6 oriented but my '92 RS is a 6....and I didn't know where else to put this and you V-6 guys never do me wrong......anyway..... I found a seized maroon GTA w/ T-Tops with the gold spoked wheels at the street department of my city. It's been sitting there for like two years. I can't get into it or anything so I need to figure out what year it is and if it has the turbo option and if they even have a turbo option- I heard that they do but wasn't sure. Any way I can do this without being able to look under the hood? I know that's kinda reachin but any help is appreciated.
Wrstdude
Old Jun 5, 2002 | 07:06 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
you can look under the hood. climb under it and reach up into the hood area. you should be able to easily pop it from under there.
Old Jun 5, 2002 | 08:11 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well the turbo option that i thikn you're talking about is the 89 TTA or Turbo Trans Am....these cars were the 20th aniversary edition trans am and were all white, also they were the indy 500 pace car, so some have the decals others don't. If it isn't white, then it isn't a turbo car. If it's a true GTA with t-tops then it's most likely a 305 possibly with tuned port fuel injection, simply because 350TPI's with t-tops is a rare combo. You can just pull the vin off the vehicle, it's located on the drivers side at the bottom of the windshield, then get on here and use the vin decoder, that'll give you the year it was made, body style (real GTA or fake), assembly plant, engine, restraint system, and something else i think, not to sure what it is. Hope that helps, but if it's maroon, i doubt it's a turbo car, instead just a v8, sorry, but hey, maybe someone had it repainted, and it's a TTA not a GTA . keep the fingers crossed.
Old Jun 5, 2002 | 08:28 PM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
if you can get into the car check the RPO codes, if it has the Y84 code its a GTA
and as said ealier, if its not white its not a TTA
check the VIN and you can tell if its a 305 or 350, and just because it has ttops don't automatically assume its a 305
mine started its life as a 350/ttop car
Old Jun 6, 2002 | 07:17 AM
SAEspinz80's Avatar
yea, nobody in there right mind would re-paint a TTA. Another tell-tale sign is look at the center pieced of the tail light assembly (you know where you put the key to pop the hatch). There should be a gold bird there, and it should say turbo underneath it. That and the Indy 500 emblems are the first signs (although some cars left the factory w/o the indy 500 emblems because they ran out). There are many others signs too, but those are the most basic.
BTW, i drove a TTA this past sunday...simply unbelievable!! teehee!
Old Jun 6, 2002 | 09:44 AM
fly89gta's Avatar
Car: 2018 Camaro SS
isn't it though
nothing beats the feeling of a turbo spooling up, wish i had a TTA though eh that's ok, just the motor is fine for me
lee01
Apr 9, 2016 01:56 PM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
