Dipstick ?'s for a dipstick
Old Jun 19, 2002 | 09:52 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Hey guys
I just got my 86 project up and running last night. Now I need to replace my dipstick tube as it broke off when the seller was removing the engine. I broke mine off my old motor trying to remove it. So how are the dipstick tubes attached to the block? I was going to pull on from the junkyard this weekend but need to know how to extract this puppy
Old Jun 19, 2002 | 02:40 PM
MDv6man's Avatar
Car: 1983, 1986
ttt... c'mon guys somebody had to replace/remove one of these without breaking it
Old Jun 19, 2002 | 03:48 PM
I Cant Drive 55's Avatar
Im not sure on the 2.8 but most chevy dipsticks just slide into the block . they have a mounting tab welded to the tube which bolts to the block to hold it in place.
The easiest way I have removed them is to remove bolt that holds tab , take a pair of pliers as low on the tube as you can get , and carefully turn tube back and forth and pull up at the same time. Be careful not to collapse the tube.
Old Jun 19, 2002 | 10:45 PM
KED85's Avatar
I haven't yet, I will be, I'll tell ya what to do.
1. GO TO YOUR DEALER AN GET A BRAND NEW ONE!
Remove the old one (good luck, unless motor outta car).
Insert new one.
Use a wrench or something like that to drive in the tube.
They do make special tools for this purpose.
You can use almost any 60* oil dipstick. I use a 1995 3.4 one for my cars (from the swap motors). Has handy "T" handle.
Must twist/flatten metal stick end for smooth penetration into tube.
Sounds perverted!
BUt, true!
YOU NEED NEW TUBE!!
Honest or else wasting time.
Old Jun 20, 2002 | 08:25 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
'55's right; if I remember correctly, the mounting tab/bolt comes off of the driver's side exhaust manifold.
tyeo098
Nov 30, 2015 06:27 PM
codeysabatini
Nov 10, 2015 04:07 PM
NZKnight
Oct 15, 2015 02:47 PM
KCG
Sep 23, 2015 09:05 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
