Question for those that have the DynoMax
Old Jul 22, 2002 | 05:27 PM
Camar_Hunter_c's Avatar
I recently got my dnyomax on and what not. I also decided to Yank the C/C. It seems now I lost some Trq in the 2-4 gears. Has anyone else had this?....
I know its not the clutch cause it was barking 2nd before I installed the Dyno.... Then after it does not "Bog" but it drags a little. I smell no burning clutch either so it leads me to believe the C/C removal also removed some vital Trq... Whatcha all think?....
You can Ask 89CamaroRS, he has ridden in my car before and after, and man before it could give ya whip lash it hit 2nd so hard, Now nothing....
Old Jul 22, 2002 | 07:17 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I know you do need some kinda back pressure on the engine to make it run right, so you might not have enough now. I was told dynomax are fairly quite?? How loud is it?? Gonna be having a 2.5-3 yo riding in mine, she hates my truck cause its too loud.
Old Jul 22, 2002 | 08:23 PM
Honestly I do not tink its loud enough. Its too quite. Maybe 10-12 Db over stock system.
I was thinking the B/P thing too... Damn it, now I need to get a small 2" piece in there.... go 2 1/4 through "Y" then right before the cat eliminator pipe throw a 2" piece then go back to 2 1/4 then 2 1/2. If nothing else it will create a nice vacuum vortex....
Old Jul 22, 2002 | 09:03 PM
Dale's Avatar
Engine: 350 S-TPI
Thanks for advice on muffler, you get it at summit?? Whats its part number. After tranny rebuild, thats next on my list.
Old Jul 23, 2002 | 11:10 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I agree with that. Whenever I had my flowmaster system on which was no cat, 3" intermidate into the muffler with 2.5" outlet it seemed that the car lost some power. I have the Dynomax now and everything is fine.
Old Jul 23, 2002 | 11:13 AM
camaro89dude's Avatar
Has anyone tried those dynomax straight through racing mufflers? they have like 2 1/4 ins and outs and get pretty big in the middle, little like a glass pack but shorter?
Another question. If I run true dual exhuast, do I need 2 o2 sensors? Or can I just put one in one pipe?
Old Jul 23, 2002 | 11:31 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Don't even think about running true duals. The only thing good would be the looks. It would sound and perform like crap.
Old Jul 23, 2002 | 12:25 PM
Ovrclck350's Avatar
First off about the sound. I like the sound because it's nice and deep....and every other exhaust I've heard on a V6 sounds like Rice.....ALSO...at WOT, it seems to scream, yet I can still hear my engine....it's a nice balance.
Second, yes, by removing the CC, you lost a lot of low end because of a lack of backpressure. On a V8, the gain is worth it because of the high end you gain, but not on the V6.
Third, true duals on a V6 sounds like absolute ****.
Old Jul 23, 2002 | 02:04 PM
Well now at 60-up it seems to have gained some more ***** though... DAMN IT you can never have your cake and eat it too! This sucks.. Oh well CatCo here I come.
Dale, I forget the part number, just call 1800 230 3030? damn off the top of my head too. And get it. Was $162? shipped?. Not bad overall, but I was just really thinking it would be a little louder/ deeper. I had to get a cat back as one of my pipes fell off the stock system, sad thing is though that was better sounding then this is...
I am thinking going to single out with a delta flow 60... Wonder how that would sound....
Old Jul 24, 2002 | 09:56 AM
Dale's Avatar
Engine: 350 S-TPI
CHC Willing to sell your old one??
Old Jul 24, 2002 | 10:57 AM
You mean my stock one?... or teh old Dynomax muffler?...
Old Jul 24, 2002 | 11:03 AM
Dale's Avatar
Engine: 350 S-TPI
The dynomax that you dislike the sound of. Muffler and tranny on my current need to do list. Tranny is going in on the 5th.
Old Jul 25, 2002 | 07:56 AM
Dale's Avatar
Engine: 350 S-TPI
Hey CHC, does wlk-17493 from summit sound right?? 152.xx for it. And did that just bolt up, do it myself I like that kinda stuff.
Old Jul 25, 2002 | 09:55 AM
well I can sell ya/er just about give ya the muffler, but I need the rest of the system.
Old Jul 25, 2002 | 10:58 AM
Dale's Avatar
Engine: 350 S-TPI
damn, I get one from summit, did i just bolt up though??
Old Jul 25, 2002 | 12:21 PM
Minus the 2 snapped bolts in the converter flange yes.
Old Jul 25, 2002 | 12:57 PM
stuart69427's Avatar
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
CHC,
Your havin fun with installing your exhuast, aren't cha ?
Old Jul 25, 2002 | 04:38 PM
Originally posted by stuart69427
CHC,
you mean the WEEK I spent installing the Hedmans/ then mine, then the Cat-Back JUST to spend another 2 days removing the hedman/mine and put the stock manifolds back on?!?!? HELL NO... LOL
Old Jul 25, 2002 | 09:20 PM
why did you put the manifolds back on?
Old Jul 26, 2002 | 09:26 AM
Because the shop that bent the tubes for me did not make them the way I wanted and they were going to cause more trouble to get them to fit.
Old Jul 26, 2002 | 09:36 AM
Dale's Avatar
Engine: 350 S-TPI
CHC, the part is on back order, they plan on shipping on the 5th, same day it goes in the tranny shop, so thats kinda cool. Think I should go ahead and start spraying bolts with wd40, or some kinda stuff like that?? So I have two bolts on the converter, and how many in the rear?? And how much of a PITA is this, whole day?? Few hours????
Old Jul 26, 2002 | 09:46 AM
well it comes with a new rear mount/hanger(on the body frame), that you have to replace/remove old one. Some of the bolts that you have to remove to drop the rear axle are in places that an air gun simply won't reach, so its knuckle scraping time. I would just remove the upper most tack arm, 3 bolds on the drivers side, and 1 onthe passanger side. Then remove the lower shock bolts(of course have the car up in the air somehow) then unbolt the other track arm on the passenger side and watch as your rear end drops 2 feet!.
The 2 cat bolts... have fun. I spent 3 hours tring to get them out then decided to hell with 'em put the gun @120 PSI rap rap rap snap.
I would suggest PB Blaster personally. but you only reallt have 3+1+1+2+2 (for the old/new rear mount) bolts to remove, and some cutting to get the old muffler/I pipe out. I think it took me 2 hours of actual work time to get all but the cat bolts out. It might have taken 10 minutes to get the system hung after wards....
Old Jul 26, 2002 | 11:50 AM
Dale's Avatar
Engine: 350 S-TPI
I have to drop the rear axle, Looks like that will be one saturday spent on it.
Old Jul 26, 2002 | 01:19 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Why do you have to drop the rear axle, just get the weight off the springs by supporting the body and the springs will push the axle down far enough to get the pipe over it.
Old Jul 30, 2002 | 12:48 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Look what I found
Ok so it looks like our best bet if you arnt going to mod your car over 150 HP is to get a 2.25" cat back. 2.50" Cat back is good for 200 HP.
I got this chart from the Dynomax Website.
Old Jul 30, 2002 | 02:02 PM
I asked people on the Flowmaster forums, They said go with a 50 series Delta flow, or a 60 Series delta Flow.
Old Jul 30, 2002 | 03:57 PM
LOL I picked out the flow 50 series.. ordering today along with a 2 1/4 high flow cat. Figure having the cat halfway would be ok...
Why do you have to drop the axle?, the "I" pipe goes over a track bar. That track bar needs to be removed. At least working on the ground you have to do that. Lifts are a different story.
billybob6110
Sep 24, 2016 09:50 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
midias
Aug 22, 2015 01:42 AM
redmaroz
Aug 16, 2015 11:40 PM
