Msd???
Old Jul 22, 2002 | 11:36 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
Msd???
ok so i want to upgrade my wires to a bigger MM, so my freind beat me to the punch in his 97 t-bird(bosch +4 plats and 9MM Ford Motorsport Wires) anyways he lost power!!
they say his ignition can pump enough juice through the wires so its like having bad plugs with the stock 7mm
question is if this is true or not??
if it is
ill wait and et the 8.8MM with MSD at the same time
Old Jul 23, 2002 | 07:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
In my s10 I went from some kinda reg wires, to taylors 8 or 8.5mm wires and I noticed a difference. 9 does sound kinda big, I would stay in the 8 range myslef.
Old Jul 23, 2002 | 08:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If your friend lost power, it wasn't because of the wires, I bet it's something he did wrong. Larger MM helps to a point, but past that (to the obscene 9mm and 11 mm wires), it just helps against crossfire and heat resistance. You'll be fine with Accel 8.8's or MSD 8.5's (my wire). Putting 11mm wires on a street car (in my opinion) looks stupid.
Old Jul 23, 2002 | 09:57 PM
camaro89dude's Avatar
Do you think the Accel wires give about same throttle response as your MSD's Tom? Cheaper at least, right?
Old Jul 24, 2002 | 04:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I'd imagine they would; keep in mind a stock wire is 15,000 ohms/foot. I forget what Accel's are, I think they go from 6,000 to 3,000 depending on how expensive they are. Plus too, a cheap plug wire set will be cheap all around, and with thin insulation (7mm), the spark can leak out easier.
Try to keep the new wires clean as they go in. Oil can attack a spark plug wire's insulation, and cause spark leak.
Old Jul 25, 2002 | 01:16 AM
Engine: 3.1
he didnt install the wires actually, we know the ppl up at r store and only get charged for parts, no labor, they did it, but he brought it back up there and had his computer rediagnosed and its runnin a lot better now, he can stay ahead of are friends GTP again
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
