Need help like now.... No fuel pressure
Old Jul 23, 2002 | 07:36 PM
widow_maker89's Avatar
Need Help!!!!No Fuel Pressure Hey guys, 1985 2.8 liter Firebird, If i run a wire from the battery to the relay wireharness it works fine and runs good, if i dont, run the wire from the battery to the relay, then no fuel pump? where else can i go, not the relay, need help with idea's?mabey a specific question what is the path of the fuel pump wireing circuit? where does it go from power source to out put:~~~pump
Old Jul 23, 2002 | 10:02 PM
Camar_Hunter_c's Avatar
If the pump comes on when you hot the relay with a remote wire.. simple prob. the normal wire has a break in it. Replace it.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
djmarch
Aug 9, 2015 05:27 PM
Kaweh
Aug 9, 2015 02:54 PM
