How come i'm topping out at 140??
Old Jul 28, 2002 | 09:31 AM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
when i try and run my car faster than 140km/h(85mph) i get this weird sound, and it's like its bucking, it sounds like
errrrr,er,errrrrrrrrrr,er,
Old Jul 28, 2002 | 12:38 PM
Camar_Hunter_c's Avatar
Its called a govenor/speed limiter.
Old Jul 28, 2002 | 12:51 PM
Car: 1986 Camaro SC
i thought they were at 170(110) on these v6s
Old Jul 28, 2002 | 05:04 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
shoudl be up higher than that....my 85 2.8L will pull nice and strong past 85 mph, infact i've never reached the 110 thingie, actually take that back, was doing 4500 rpm once in 3rd, think that was it, cause the car wouldnt go any faster, and the RPM's never got any higher....
Old Jul 28, 2002 | 06:51 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Sounds like you have 3 choices to me..
1. That e-prom burning sticky
2. Jetchip
3. Hyperchip.
Old Jul 28, 2002 | 07:06 PM
Car: 1986 Camaro SC
i think its that damn 700r that wont shift into 4th i think it is.. at WOT, cause tonigt i got it to dip past 140, but i had to let off and almost floor it again, and about the chip, have a link with info???
Old Jul 28, 2002 | 07:14 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
umm
The transmission will not shift into overdrive at WOT (4th)
Thats how these all are.
Old Jul 28, 2002 | 07:44 PM
Car: 1986 Camaro SC
does it sound like it tries in yours at 140?
Old Jul 28, 2002 | 08:01 PM
ummm
I'll find out on September 15th when I get my license. lol.
Old Jul 28, 2002 | 08:45 PM
Car: 1986 Camaro SC
someone told me it could be my torque converter, anyone know about that??
Old Jul 29, 2002 | 11:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I doubt it'd be the torque convertor. That's driven by engine rpm, not car speed, so you'd have trouble at a certain RPM in all gears. I installed the B&M 4-3 kickdown kit; it's a replacement TV sleeve that allows you to put the go-pedal almost to the floor while in 4th gear. It prevents line pressure from downshifting the trans. It also will basically lock out 4th- if I'm doing 55-60 mph on a highway, I need to floor the gas all the way to get the car to drop into third- instead, I just slap the stick down (B&M megashifter) into third. I like it, but some people might find it annoying- and people that don't know about it might wonder why the car won't speed up
GM does have a 3-4 WOT upshift kit for the 700r4, it came in the B4C police camaros and the corvettes. It's more pieces than just a TV sleeve, though. The B&M kit can be installed without dropping the valvebody; I think you have to drop the valvebody for the GM kit- and at that point, you should think about installing a full Transgo shift kit while you're that far into the trans. You could do the B&M kit next time you drop the pan to change the fluid/filter.
Old Jul 29, 2002 | 07:50 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Ohh. Tom P said "slap the stick down"
Uh huh huh huh.
The preceeding comment has been brought to you by Beavis and Butt head
Old Jul 29, 2002 | 10:04 PM
camaro89dude's Avatar
Is that transgo kit the one that costs like $120?
Old Jul 30, 2002 | 01:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL, Eric! Yeah, that's the TransGo kit. They used to come with a video showing "how to install", maybe they still do. But basically, "you get what you pay for" for shift kits. And never ever buy the B&M TransPak. It's the exact same thing as the B&M Shift Improver Kit!! Know the difference? The TransPak comes with a new trans filter, the Shift Improver Kit doesn't. So you're buying a $25 trans filter. Might as well just go to Pep Boys or AutoZone and buy a $12 Purolator trans filter.
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
