Smog Pump
Old Jul 30, 2002 | 09:51 AM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
Smog Pump
how do i take it out and what advantages/disadvantages will i have without it?? note that there are no emissons test here in NFLD.
Old Jul 30, 2002 | 06:03 PM
Car: 1986 Camaro SC
no one?
Old Jul 30, 2002 | 06:44 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You just remove it; if there's any vacuum lines or left-over open hoses, plug 'em. There's no real disadvantage to missing it; the cars can pass emissions without them. Do you have a manual trans? My '86 2.8 with Automatic didn't get a smog pump. My '86 GM Service Manual (Helminc.com) shows that only '86 2.8's with a manual trans received the smog pump. Stupid, huh? (well, good for me, bad for you! ) But two otherwise identical cars, why would one get a smog pump? Did they figure the manual-trans guy would be racing his car and creating more pollutants?
Old Jul 30, 2002 | 07:21 PM
Car: 1986 Camaro SC
the smog pump is the canister on the drivers side up neqar the nose of the car in the corner right?
Old Jul 30, 2002 | 07:22 PM
Car: 1986 Camaro SC
and i also have an automatic
Old Jul 30, 2002 | 09:10 PM
Camar_Hunter_c's Avatar
The smog pump is the thing(device) that is mounted below the alternator(on the serpinetine belt)
Do you have a Serpintine or "V" belt sytem? (Serpintine is a single belt) If so yes you can remove it easily, go to my site( http://www.geocities.com/generationx.../3rdgenheaders ) to get the new routing and belt length required.
How do I know this? I took mine off about 2 weeks ago.
Any noticable gains? not really, then again I lost alot of power when I took off my converter so....
PS if that link doe snot work then go to www.geocities.com/generationxracing/MainPage and look at the header link. Should be on the first page if I remember corretly.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
