engine RPMs climb to 2300 at startup
Old Jul 30, 2002 | 03:38 PM
Switzy's Avatar
I have an '87 Camaro RS 2.8L MPFI V6 and have a concern about the engine RPM at startup.
Upon starting the engine, the RPM's climb to ~2300 and remain there for about 2 sec before slowly reducing to ~800 over the next 7 sec. I don’t remember this being normal which is the reason for my concern.
This started happening after I replaced the thermostat. I cleaned various connections, including the throttle body where I removed as much of the black, I take it exhaust, buildup as I could. I also accidentally created a small opening in the plastic vacuum lines that connect on top of the throttle body. I taped up the opening with electrical tape as best I could.
Jacob
Old Jul 31, 2002 | 06:50 PM
CamaroStud1988's Avatar
Car: 91z28 and 88 SC thats for sale,in the sig
Engine: 305 TPI soon 383 stroker or 327
Transmission: t-5
vacuum leaks willmake ur engine run like total hell. i had a bad vacuum leak a few weex ago,engien wuldnt idle,brakes had no power.all cuz of a small lil piece of plastic.when my intake manifold was leakin,my rpm's did somethin like that to though.
Old Jul 31, 2002 | 06:56 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Vaccum is the first place too look.
Some one had a problem like this a while ago. It turned out that there Vaccum line that hooks to the brake booster was broken off or fell off. So I would suggest you look there first.
eightsixseven
Dec 16, 2024 01:50 PM
InfinityShade
Aug 22, 2015 08:00 PM
jbd1969
Aug 17, 2015 07:06 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
