Just wondering what my rear gears are?
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I did the 70 MPH test and got about 3100, RPM's
What is the rear gear on a 91, 3.1?
Car: 91 Camaro 77K
Engine: 3.1 Vslick
No, when you are going 70 MPH, you drop it into Drive, and the RPM's are supposed to read what your rear gears are....
That's why it is higher...
It's actually about 2250-2500 when I'm in OD and doing 70...
Car: 1986 Firebird
Engine: 2.8 V6
I thought the 3.1's with auto's got a 3.23 rear gear, not 3.42 ...
Do you have the original size tires/wheels on it? If the tires/wheels are different, your speedometer will be off and you couldn't do the 70 mph in 3rd trick.
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well I have 215's, and I think 3.23 would probably be closer, since It said 3100 rpm's when i did it.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yup, found right here @ ThirdGen.org
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
