Couple of things:
Old Aug 19, 2002 | 01:39 PM
Brian K's Avatar
Couple of things:
Anyone add new LCA's to their cars. I am looking into it and wanted some feed back.. I am looking for better handling until I get money to really do some engine work.
Does anyone know what size sway bar an 86 Z has?
My wipers do not go up or down.. They go inch then back down... Any ideas? Before this occured I noticed low would no longer work, then it had to always be on HIGH, then not even high works, just that 1 inch movement thing I get.
Rear main seal? Anyone do it yourself in your garage or is this someting a shop should do?
Old Aug 19, 2002 | 05:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Sounds like the wiper motor might be burnt out; have you taken the motor out? My wipers stopped one day in the snow, luckily I was 150 feet from my house; made it inside. The wipers wouldn't start up again. I figured they were frozen; next day, I tried the wipers again- nothing. So I removed and disassembled the motor, cleaned the brushes, put it back together, and the silly thing has worked perfectly since then- and that was in January of '96!
A rear main looks like a pain in the butt... especially with dropping the trans. Did it blow out?
Old Aug 19, 2002 | 07:01 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: Couple of things:
if the RMS isnt that bad yet, wait until you need to drop your trans and do both at once
if your not a pro, i would only attempt this if its a 1 piece
i believe for a 2 piece you need to remove the motor and then the crank and mains
for the one piece you pry it out (using a screwdriver VERY carefully, or the proper Kent-Moore tool) then use the old RMS and place it against the new one..........work it in with a hammer VERY carefully OR the proper tool (which i know exists)
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Linson
Oct 1, 2015 09:50 PM
