Compression of 3.4
Old Aug 25, 2002 | 12:34 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
Compression of 3.4
In some of the other posts we were discussing about how the compression for a turbo setup should be around 8:1 in order to run a large amount of boost (like 15-17 range). So I started to wonder what the compression ratio was for the 3.4. I'm guessing that it's probably close to the 2.8, put maybe I'll get lucky and it'll be at the magic number. So anybody that's done the 3.4 swap, or knows about the engine, please let me know. Thanks, Joe
Old Aug 25, 2002 | 12:37 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
9.0-1
Check here for more specs
Old Aug 25, 2002 | 02:36 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
I thought it was 9.2 to 1???? Thats what I read about it.
Old Aug 25, 2002 | 04:17 PM
KED85's Avatar
According to GMPP it's 9.0, when it's a new long block (crate engine).
I know my Firebird 3.4 engine is atleast that 9.0 compression. I registed 175+ on each cylinder, as I adjusted valves.
I believe the 3.4 in my Blazer will register very close to those specs, too. That's a 50K mile engine I've installed in that vehicle.
Old Aug 25, 2002 | 06:08 PM
What is the next piston up as far as ratio, I don't want to have custom ones made but would like a little more then 9 to 1.
Old Aug 25, 2002 | 06:19 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
depends on the head CC
just use a thinner gasket or better yet, just get your heads shaved
FormulasOnly
Jul 23, 2018 08:47 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
WhteRbt
Sep 21, 2015 09:48 AM
