V6 to 350
Old Aug 31, 2002 | 03:49 PM
Camaro_1986_19's Avatar
V6 to 350
What would I have to do to get a 350 TPI in my 6 cylinder?? What would I have to change??
Old Aug 31, 2002 | 05:47 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
You should search old threads.
But your going to need transmission, engine, FI, Harness, maybe new guages, Rad, Front springs, and maybe drive shaft.
Old Aug 31, 2002 | 06:30 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
entire engine including all accesories, TPI unit, motor mounts, a brake line, radiator, need a new transmission, engine harness, radiator hoses, front springs..........the list goes on and on
Old Aug 31, 2002 | 10:25 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
well lets see, it'll take a mighty load to do the swap, would be worth it, but maybe not as worth it as swaping to a newer LT1 or Ls1` setup, being that you'll have to swap nearly all the same stuff for either. basically the things that were stated earlier will definately be needed, lets see, hmmmm. Radiator (get it from eh, salvage yard, or maybe autozone), v8 motor mounts, engine, computer, (any sensors), computer and wiring harness, transmission for a v8 car, 700r4 would work, along with a six speed, ur choice. Hmmm, lets see , driveshaft will be the same, rear end needs changing if you'd like to, doesn't matter though, (till u break it) and front springs if u want it to handle like a super f-body again, or if u just don't want the front end to sit lower. NO need if u really don't wanna change it, won't hurt anything in the short term. That should be it, everything but engine and tranny could easily be found in a bone yard, i'd say everything but the engine/tranny combo (unless you're doing a complete rebuild on both) becuase u never know what type of hell they've been through.
Old Sep 1, 2002 | 03:35 AM
zer0321's Avatar
I don't know why you would bother...IMO it's not worth the upgrade
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
