GREAT ADVICE,but...
Old Sep 17, 2002 | 06:13 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
GREAT ADVICE,but...
...after I flush the system as previously stated, what is the best stuff to use on the engine block drain plug threads to install back on the block without leaking?And....does anyone know the angle of PVC pipe coming off the throttle body to angle towards the air filter housing( ie..45*,60*...).Thakns guys.:hail:
Old Sep 17, 2002 | 09:49 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
the best stuff to put on the threads is "permatex" I think it goes by another name. It comes in a white small container with a siliver cover. It's brown and sticks to everything LOL. You can also just put the engine plug back in dry. IT"S tapered pipe thread that seals like a pipe. RTV is ok but kind of thick.
Old Sep 17, 2002 | 10:27 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if it's that indian head gasket shellac, it's in a brown container, & the cap is also part of the goop handle/applicator. Stuff also makes a good radiator repair
Ghettobird52
Apr 21, 2020 08:44 PM
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
E Rod
Aug 28, 2015 05:17 AM
neekolzun
Aug 24, 2015 04:59 PM
formula_novice
Aug 18, 2015 08:48 PM
