is it illegal to put nos in my car and run it on the road?
Old Sep 23, 2002 | 09:36 AM
johnboy's Avatar
I think it is but is it illegal to put nos in my car and run it on the road?
Old Sep 23, 2002 | 11:35 AM
GhostRider84's Avatar
Depends on your state , but if it is, it is a stuppid law - NOS puts more Oxygen into your combustion chamber - it should make your engine run cleaner. (for the breaf seconds you are actuality using it)
Old Sep 23, 2002 | 11:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've heard that in NJ, if they catch you with the bottle connected and the valve open, they impound the car. I also hear that if the cop's being a *****, they can arrest you for carrying a controlled substance!! Aint that some sht.
Old Sep 23, 2002 | 02:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
not sure but ive heard of cheater systems, using quick connect hose like you see on truck plows. it disconnects without leaking anything, even under pressure.
Old Sep 23, 2002 | 03:28 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Technically in all 50 states, its legal to have in the car for transport.. so you can have it in there.. the line gets drawn at connections.. if the hose is connected to the bottle valve, then its illegal.
Old Sep 23, 2002 | 05:10 PM
Ragnarok_Tyr's Avatar
It varies from state to state....most of the time the hard and fast rule is that you can have it on your car, but you cannot RUN it on the street. As far as what rules are in place for your state/municipality, call your local emissions testing center, and they'll tell you the deal.
Old Sep 23, 2002 | 05:29 PM
Camar_Hunter_c's Avatar
in somen states yes. But thats why you have an electronic valve. cause the states that do outlaw it, the system has to be hooked up. That valve disconnects it.
Old Sep 23, 2002 | 06:33 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Its called Nitrous, Nitrous Oxide, or the bottle, not nos. Unless you're pronouncing it N.O.S. letter by letter.
N.O.S. stands for Nitrous Oxide Systems, A brand of Nitrous.
It is not illegal here in Alabama. Maybe it is in your state.
Old Sep 23, 2002 | 08:40 PM
....or Juice, Squeeze, Giggle Gas, but never, ever naaaaaaawwwwwwsssss :nono:
Old Sep 23, 2002 | 08:51 PM
Well said!
Old Sep 23, 2002 | 09:00 PM
AFrikanGoodTime's Avatar
Scuba shops have all the fittings you'll ever need for quick disconnect of a nitrous bottle. Some of my Scuba tanks have a working PSI of 4500 and I can connect and disconnect it all day long without a leak. Some divers also use a blend called Nitrox-- Its a nitrogen enriched air and the hose handle it fine, they have to because our life depends on it down there.
Old Sep 23, 2002 | 10:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Just thinking, dont know the safty issues, or if the track would like it but on the street. you could hide the bottle in a speaker box. bolt it down and run everything out the bottom and hidden.
a cops would need a warrant or need your permission to look in the truck of a regular car, but in a thridgen n all that glass its kinda hard to hide.
Old Sep 23, 2002 | 10:19 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
if its a vented or port box a good bass tune would keep it free of gas build up if it leaked by chance.
Old Sep 26, 2013 | 12:40 PM
MAS247's Avatar
Re: is it illegal to put nos in my car and run it on the road?
actually Nos is a brand of Nitros-oxide good sir
Old Sep 26, 2013 | 01:23 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
this thread is from 2002...
Old Sep 26, 2013 | 02:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
back form the dead ehy?
well update, lots of states [ like Ohio] have new laws, NOS in a street car is an automatic street racing offence, your car can be siezed and or crushed.
thanks to all the fast n fake movies.......
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Exxon Limited
Aug 9, 2015 08:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
