Wierd...
Old Oct 1, 2002 | 06:43 AM
Azure's Avatar
From: "No one cares if you're in before the lock!" - Best quote ever.
Wierd...
Cooler mornings, start up the car, blah blah....runs fine...UNTIL....throw on the defrost...then there's an excess amount of exhaut that begins to flow out, and my RPM's jump considerably. It isn't when the fan is on, but rather only when the heater/defrost is on - A/C just bogs the vehicle down. WTF is with this...?? Thank *** I'm not going to have to drive this car in another winter....!
Old Oct 1, 2002 | 12:58 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
How many rpms are we talking here? Any colors in the exhaust besides a hazy greyish? Btw, if a/c makes your car bog a little when you turn it on...does it hum too? Mine does..it's the clutch. I'd try running a can of 134-a with oil in it through the system and see if it helps the clutch a bit... The hum and powerloss is because the clutch is grinding and putting more resistance on the belt. As far as your main problem, wish I had a clue in hell but I don't.
Old Oct 1, 2002 | 02:24 PM
Azure's Avatar
It's the 700r4, or whatever, so it isn't the clutch... =) The main problem only seems to be when the car is cold, not nearly as bad any other time....hmm....
Old Oct 1, 2002 | 02:29 PM
92RSMuscle's Avatar
could be a hole in the exhaust manifold that is being picked up by the blower?
Old Oct 1, 2002 | 02:39 PM
Xenodrgn's Avatar
Azure... he ment the clutch on the AC compressor...
Speaking of Azure... I bowl with an Azure Zone Pro for the medium oiled lanes... :rockon: I love that ball...
I'd say exhaust leaks... With my cowl hood thier worse than ever... I don't need brain cells but at least I have killing them my way... :lala:
dazed: "NJIT? Yeah thats a great place for pizza!"
Old Oct 1, 2002 | 02:49 PM
Azure's Avatar
lol! My bad.......I'll check for leaks tomorrow, though I didn't see anything noticable by the manifold earlier...we shall see...
Old Oct 1, 2002 | 06:46 PM
Nixon1's Avatar
Yeah..the clutch on the compressor is the part on the front. Just let the car run, pop your hood, and flip the a/c on, and you'll see the clutch cycle. If you're buddy-buddy with a local mechanic, he'll probably top the freon off for ya. Just run to the local parts store and pickup R-134a w/ oil (assuming you've got a converted system, which I hope you do...R-12 is expensive as hell now)...and just have the mechanic hook it up. You just gotta hold the car around 2,000 rpms I think and let it run through..that should oil up the clutch at least a LITTLE bit..might not help a lot, who knows...I still have to do it.
insomniac
Brakes
Jan 18, 2016 08:26 AM
MustangEater82
Feb 24, 2013 04:04 PM
cIaRmOaCrZo
Theoretical and Street Racing
22
Jul 9, 2010 01:38 PM
Aarons92Maro
Oct 12, 2009 02:22 PM
xklipze
Aug 10, 2006 06:58 PM
