Pulls right then centers when braking
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
So my car has this wierd issue where when braking and it isnt everytime but about 80% of the time, but it pulls right then back center. Like one caliper was coming on faster then the other. So I put new calipers on the vehicle and still same problem. Now my drivers side front control arm bushings are a little worn do you think that can cause the issue. Its not severe but it is annoying. And again its not just to the right it happens real quick but its a tug to the right then back center. Very wierd... anyone come across this before?
Re: Pulls right then centers when braking
Happens all the time.
It'll get progressively worse... it'll eventually get to where the car pulls left all the time, until you hit the brakes at which point it will VIOLENTLY JERK right, then when you let off the brakes, go back to pulling left. If you hit the brakes real hard, it'll pull left even worse when you let off of them.
Cause is, the fittings at the ends of the rubber hose (left front in your case) have rusted the teeeeeny tiny hole in them almost shut. Fluid can't get in there as fast as it can on the right.
Replace em both. They're CHEEEEEEP.
Engine: 5.7 L98
yeah for the 20 bucks def worth a shot. will do tomorrow... only thing is hoses only about 3 years old and it isnt really pulling anywhere not on the brakes
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
It's not necessarily rust, but the inner liner of the hose can come loose from the braid & it will do the same thing. Initial fluid pressure will close off the hose. Regardless... change the brake hoses.
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
I agree, it's a restriction in the lines. Almost always a brake hose. Like Lonnie P said, could be the inner liner collapsing and causing the restriction. You'd never see it externally.
Engine: 5.7 L98
the hose fixed it!!! thanks
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Speaking of hoses,.. whats the difference with these...looks to be the same part numbers.
http://www.ebay.com/itm/Russell-6920...pVV--a&vxp=mtr
http://www.ebay.com/itm/Russell-6920...pVkp3W&vxp=mtr
http://www.ebay.com/itm/Russell-6920...ZTn6ZD&vxp=mtr
price and seller right?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The 84-88 version usually has four lines: two front, one at the diff, and one at the pass side caliper. 89-92 has five lines: two front, one at the diff, and one at each caliper.
JamesC
Looks like the drum brake kit... 3 lines.
But, it says "Russell"... RUN AWAY.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
