Heat Shield
Old Oct 3, 2002 | 03:34 PM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Heat Shield
Damn heat shield fell of my cc, fell off and got ran over actually. Will my car be okay without it? Or should i seek out a new one?
And i was wondering if i could disable my Vats easily, to do a test on my starting problems, then re enable it? I am still having that problem. Put the key in, turn it, nothing but a click. Next time i turn it, starts right up. I have replaced starter(with new solenoid),cables going to starter, and my ignition switch(thing i put my key in) has been rebuilt. Any ideas?
Old Oct 3, 2002 | 05:58 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
There is a tech artical on disabling your VATS.
I'm not sure about the heat shield thing.
Old Oct 3, 2002 | 06:47 PM
PeNZ's Avatar
I run with the cat shield off too, mine was rattling, so i ripped it off, and its fine to run without it, because there is a factory heatshield on the floor pan already, you'll be fine.
Old Oct 3, 2002 | 07:29 PM
9D1BURD's Avatar
Car: 1997 Z28
thanks, i will check out the tech article. I was hoping the heat shield wasn't a problem.
Old Oct 4, 2002 | 10:34 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I agree; I think that heat shield was there to prevent fire when parking over leaves or grass, which we shouldn't ever do, anyway...
I ripped my hand open on one of those damn heat shields... when I was doing that 2.8/2.8 swap on my friend's old '89 Camaro. I was loosening a trans-to-engine bolt, pushing on the breaker bar. (My feet were under the front bumper, head by the transmission.) The bolt loosened! My fingers went SMACK right into the cracked/rusted heat sheild of the cat- talk about blood and PAIN... after I cleaned the dirt/rust out of the cuts, I put on a ton of bandaids, and put my Mechanix gloves back on. (oops)
Old Oct 4, 2002 | 10:39 AM
9D1BURD's Avatar
Car: 1997 Z28
well, i wont mess with the shield then. I just have to figure out this stupid start problem. Thanks for all the info, and tom, good job on the welds
Old Oct 4, 2002 | 12:45 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hehe, thanks! It'd be a better job if I had sprayed some paint or undercoating on them before it rained yesterday; oh well, I'm not that worried about a little more rust
And I wonder about the VATS, because you said you get a "click"... I think if VATS was acting up, you wouldn't get any click.
Old Oct 4, 2002 | 02:25 PM
9D1BURD's Avatar
Car: 1997 Z28
I have to double check on the click, it may or may not actually happen. I have been driving my ranger lately, getting ready to put the bird up for winter. Maybe the guy who redid my ignition was an idiot
sheachopper
Jul 31, 2019 11:27 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
