Fuel filter?
Old Oct 5, 2002 | 08:46 PM
84and85bird's Avatar
Car: 84 Firebird & 85 Firebird
Engine: 2.8 V6 : 2.8 V6
Transmission: 700R4 : 700R4
Fuel filter?
As I was pulling into the drive of my apartment complex today I noticed that my power steering had quit on me. I nailed the breaks has hard as I could to slow down in time to make the turn into the drive. I knew that the engine had quit on me at this time because I had no power breaks either. After just making the turn into the drive I noticed my SES light on, so I stopped the car to attempt to restart it. It wouldn't start after several tries so my girlfriend steered it to a parking spot as I pushed it. I checked for error codes but nothing showed up other than a code 12. I started it agian and noticed that my fuel pump still seemed to be making some noise, and the engine would try starting but couldn't. Could a clogged fuel filter be the problem? I guess that I am going to try replacing that first. If it was the fuel pump should it have gave me an error code?
Old Oct 5, 2002 | 10:25 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
also check to see if fp is getting power. check/replace: fp relay. oil pressure switch (sends signal to fp relay, fuel filter, fuel pump pressure. basically diagnose all things that are involved in delivering fuel to the car.
Old Oct 6, 2002 | 05:06 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
TTT
Old Oct 6, 2002 | 07:33 PM
I bought a new fuel filter and worked on putting it on the car today. It was on really tight. I managed to get one side off, but I ran into a problem trying to get the other side off. The gas that leaked out of the line I got off made my wrench that I had on the nut to the fuel line slippery. The wrench sliped out of my hand letting the wrench that I had on the fuel filter turn. I ended up bending the fuel line. Now I have to cut the end of the old fuel line off and put a new piece on the end.
Old Oct 6, 2002 | 09:15 PM
Engine: 5.7 / 7.4
I haven't changed mine yet
also, check fuel pressure. broken lines are a bytch
Old Oct 7, 2002 | 06:55 AM
Horst's Avatar
Car: Firebird
Engine: 3.1 L
Transmission: auto
same thing happened to me, changed all: IAC, MAF, Filter etc. and no changes, finally it was the ECM.
Horst
Old Oct 7, 2002 | 10:02 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Is this the '84 Firebird 2.8 or the '85 Firebird 2.8?
Old Oct 7, 2002 | 10:05 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Are you getting spark? Could be a bad ignition module or coil...
Old Oct 7, 2002 | 12:07 PM
Its the 85 Firebird that I'm having problems with. It seems like the engine is getting spark, but I'm not %100 sure about that. When I managed to get the one side of the fuel filter off, it looked almost like dirty oil coming out of the filter. So even if it isn't the filter it really needs replaced anyway. I tried starting the car up for a second with the once side of the filter still off just to make sure that the fuel pump didn't totally give out on me. It sounded ok and shot out gas, so I assume that the pump is ok. Hopefully I'll get the fueline repair kit tonight and get the fuel filter back on it tonight, assuming that I find a ride to an auto parts store.
Old Oct 7, 2002 | 10:28 PM
devianb's Avatar
I just had my fuel pump replaced after 100,000 miles. It could be something electronic as well. Wires tend to burnout when they get old.
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
