Did I compresion Test.. Resaults:
Old Oct 6, 2002 | 02:08 AM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
I did a compression test, ALL of them read 150PSI.
My haynes manual says Psi should be 100-150.
So my engine must be running pretty strong then right?
What compresion do you guys got?
Old Oct 6, 2002 | 08:33 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
155 here, on all but one that spiked 170 - rearmost passanger cylinder.
Old Oct 6, 2002 | 09:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I got 120's on my 2.8l in my s10. Maybe thats where my problem is. Please others post to help me decide!!!!!!!!
:hail: :hail: :hail: :hail: :hail:
Old Oct 6, 2002 | 09:48 AM
AFrikanGoodTime's Avatar
You've got excessive carbon build-up on piston and head. This causes the raise in compression.
Old Oct 6, 2002 | 06:02 PM
Doward's Avatar
Quite probable. As for the 120 psi, if they are all around there, I wouldn't worry too much - maybe squirt some oil in, then redo one of them - if it comes out noticeably higher, its worn rings.
As for the carbon buildup, I'm sure that's what it is. No biggie though, as long as they're all good, I'm good to go!
Old Oct 6, 2002 | 11:09 PM
KED85's Avatar
My 211,500 mile S-10 Blazer mill have only 50 pounds per cylinder.
It ran.
YOu got plenty to go!
New chain, rebuild distributor, max fuel output, good to go for LONG TIME!
Don't open engine for hopping it up,
Drive it into the ground. Rebuild body before the engine dies, then add the "new mill"
It'll be a way cheaper project that way.
Old Oct 7, 2002 | 08:49 AM
86redbird's Avatar
Car: 88 Firebird, 86 Firebird
"You've got excessive carbon build-up on piston and head. This causes the raise in compression."
All six cyls on mine are either at 160 or 170 and have been for a couple of years (though possibly worse now). Will it do any harm leaving it like that, or should it be a priority to fix?
Old Oct 7, 2002 | 09:52 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
oops pressed post twice
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You could spray some water through the TB to decarbonize the piston top/combustion chamber, but I wouldn't make it too much of a priority, unless you notice excessive pinging.
Last time I did a check, which was a while ago, 5 out of 6 cylinders were in the 140-160 psi range. THe #1 cylinder was the dog at ~120 psi, probably caused by that spark plug that blew apart from when my timing was way overadvanced.
Old Oct 9, 2002 | 02:29 PM
devianb's Avatar
145 and runs strong, although weak in the rpm level.
Old Oct 9, 2002 | 03:04 PM
KED85's Avatar
Weak springs
or exhaust flow choking it or bad air inlet design.
That's reasonable-good compression.
BitchinRS
Jan 4, 2005 12:23 AM
BMmonteSS
Aug 27, 2003 11:16 AM
camaro03
Dec 28, 2001 02:41 PM
mustangs killer
Mar 6, 2001 03:35 PM
mustangs killer
Mar 6, 2001 01:40 PM
