any difference between 2.8 and 3.1 plug wires???
Old Oct 9, 2002 | 04:09 PM
squirrelybird's Avatar
hey guys...i looked up the part numbers...ACC-4079----for 3.1.
ACC-4078----for 2.8. I think they are 8.0mm???? anyways, summit has the ones for 2.8 in stock...the ones for 3.1 out of stock(backorder). Well i have a 3.1.....do you think there is ANY difference in the two sets of wires?????
Old Oct 9, 2002 | 05:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There might've been some difference in length, but otherwise, I don't see a problem. Both cars use the same ignition system, both cars use the same part # distributor cap, and there's no difference at the spark plugs, either. I say go for it! (Weird about the different part #s, though.)
Old Oct 9, 2002 | 06:17 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Nope - just get the cheaper ones
Unless the 2.8 are 7mm, and the 3.1 are 8mm... I believe accel's part number for 8mm for the 2.8 is ACC-4021, tho...
Old Oct 9, 2002 | 09:05 PM
theyre the same price.
4021? hmmm ill look into that.
Old Oct 10, 2002 | 09:04 AM
well...from what i see, the 2.8 ones ARE 4078......anyways..this is interesting...they are not just 2.8, 3.1.....they are actually 4079 for like 87 or 88-92, and 4078 for earlier years. hmmmmm
Old Oct 10, 2002 | 09:27 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
maybe diff p/n for fwd & rwd engines, such as DIS & whatnot
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
