T-Stat Removal??
Old Oct 18, 2002 | 06:51 PM
89RSOwner's Avatar
T-Stat Removal??
Do I really have to take part of the throttle body off to get this POS off? Looks like it's stuck closed and I can't see any other way to remove it.
Old Oct 18, 2002 | 07:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I think TomP said that if you use some swivels, extension, & the right size socket, it can be done w/o taking the tb off.
Old Oct 19, 2002 | 08:21 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I took it off anyway - you wouldn't BELIEVE the gunk in that t/b! Clean it all out, while you're there.
Old Oct 19, 2002 | 08:48 PM
Engine: 5.7 / 7.4
yep, gunk from that tube from the valve cover, & the egr tube in the back.
Old Oct 23, 2002 | 01:05 PM
Brian K's Avatar
When I did mine it was always easier to remove the throttle body.. Then you can clean it real nice.. It also helps to removethe upper plenum and clean that too...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
