2.8 Valve Cover Pass. side ValveC. removal pro's see this:
Old Oct 26, 2002 | 09:26 AM
89RSOwner's Avatar
What would the EASIEST and MOST EFFECIENT way to do this? I need to stop that damn ticking whatever it is. It's driving me nuts! Might be a loose rocker as it has got steadily worse over a 3 month period. (with 1,000 mile trips) Either that or a bad lifter? kinda like a tick/rattle. Sounds like the back cylinder. So might as well adjust them all while Im at it BUT, how to get the damn thing off!
Old Oct 26, 2002 | 03:08 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You have to pull the upper and lower plenum to gain access to all of the cover holddowns (the downside of the compact 60* V6).
You'll probably also need a 10mm deep socket to get them off.
Old Oct 26, 2002 | 04:26 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the valve covers on my 3.1 are on with inverted torx
Old Oct 26, 2002 | 06:06 PM
Engine: LH0 3.1L
Doesn't it have a stud with the inverted torx end and a 10mm nut on the stud?????
Old Oct 26, 2002 | 06:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
10mm is the is of the bolts holding the top plenum to the middle.
The inverted torx,..........when I put the covers back on my motor, I just 4 studs..two on the top two holes of both covers to hold it in place. I used the 3.4 bolts for the rest, especially the PITA rear of the covers. If you can, go to a dealerhip & get that hardware o you wont need to that deepwell ocket as much.
Old Oct 26, 2002 | 07:09 PM
heh never looked that close
once i get the 350 TPI built, i'll be pulling the 3.1
Old Oct 26, 2002 | 10:47 PM
KED85's Avatar
IF I was you......
I'd just change oil add a top end cleaner & see what happens.
To remove, you need 10mm 12 point socket or wrench
Take top flip over keeping all things attached to top intake part.
Next is middle intake. Upon removal of that you also need remove the fuel injectors and the o-rings will be brittle.
Really try a top end addative or just add a slightly thicker mixture of oil, to see if that calms down the noise (and your complaints of it)
IT may end up being the most simple cost effect way to remove valve train noise.
Old Oct 27, 2002 | 10:03 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
And you're sure it's not an exhaust leak and/or snapped bolt between the manifold and head, or between the manifold and y-pipe? Time to get a louder stereo!
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 8, 2015 01:18 AM
