What's the purpose of these plug covers
Old Nov 2, 2002 | 09:58 AM
dsaint1347's Avatar
I have a couple missing from my car, what does it do and we really need them?
Old Nov 2, 2002 | 10:51 AM
David Blalock's Avatar
I'm pretty sure they're heat shields to protect the wire boots though there may be another reason and to me they seem to get in the way all the time.
David
Old Nov 2, 2002 | 11:28 AM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
you don't need them but they can be useful. by pulling on the metal covers you prevent breaking your spark plug wire. If you pull on the wire, chances are it will break,
If you choose not to use them, just remember to pull on the wire boot not the wire
Old Nov 2, 2002 | 01:39 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
If your using aftermarket high temp spark plug leads you don't need them.
Old Nov 2, 2002 | 02:41 PM
mvftw's Avatar
If your using stock wires, use the shields!
Old Nov 2, 2002 | 09:57 PM
WaynesRS's Avatar
You really only need them on the #1 and #3 plugs , these are the plugs on the side of the EGR valve . But , if you have all but 2 , you might as well use the ones you have .
Old Nov 3, 2002 | 05:45 PM
devianb's Avatar
I don't use them anymore since I lost one of them and my car runs fine.
Old Nov 3, 2002 | 06:07 PM
Camar_Hunter_c's Avatar
If you have QUALITY Aftermarket wires you don't need them.
Old Nov 4, 2002 | 11:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think they might be some kind of radio interference shield, because I don't see how they'd protect the boots from getting melted. If that were the case, every car woudl have 'em. But I didn't see any difference, melt-wise or radio-static-wise, after pulling them back in '94- even before using MSD wires. Found one in the girlfri..uh...fiance's 4th gen, wedged underneath the hood latch. It's the only one she's got on that car... none of 'em were on the plug boots.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
db057
Sep 4, 2015 07:57 AM
