RMS leak, Is it a one or two piece on a 4th gen, 3.4
Old Nov 5, 2002 | 01:12 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I'm sure someone here knows. Ive got a customers 94 firechicken and it appears the RMS is leaking. On that 3.4 is it a one or 2 piece RMS.
Thanks.
Old Nov 5, 2002 | 01:44 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
after 1985, all of the 60 degree V-6s got a one piece RMS.
I'm not sure if the "plug" for the distributor hole has an O-ring on it, but the earlier V-6s had an O ring on the distributor that, when it leaked, it looked like the RMS was leaking.
Old Nov 5, 2002 | 02:40 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the oil pump/decapitated distributer thing on the 3.4 has the o-ring also.
Old Nov 5, 2002 | 06:39 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thanks for the replies.
The oil is only on the bottem of the engine bordering the inspection cover and the oil pan so its either gotta be a rms or pan gasket, V shaped drip.
Casey Meyers
Mar 2, 2016 10:46 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
MY87LT
Aug 17, 2015 08:43 AM
sreZ28
Aug 14, 2015 07:48 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
