Pics of my CAI
Old Nov 5, 2002 | 11:16 PM
jesse23's Avatar
Pics of my CAI
1st The TYPE R CAMARO INTAKE!!!! OH NOES!!!!
And again!
Real Ones
Old Nov 6, 2002 | 12:58 AM
devianb's Avatar
Looks like you went down to the home depot for that one. Looks clean and organized though, sure beats the factory airbox. My first attempt at making an intake tube was made from PVC plastic pipes too, but since then I swapped it for a 3" aluminum piece I got from an exhuast pipe. I still used part of my old intake tubing as a spacer to mate the aluminum tube to the factory ribbed intake tube.
Here is a pic of my intake, although it is not all that easy to see.
Old Nov 6, 2002 | 07:22 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I would love to find a place that can manderel bend pipe, and us not even have to use that damn rubber flex hose.
Old Nov 6, 2002 | 08:47 AM
Keoki_Firebird89's Avatar
just buy a honda intake
connect it to the the rubber hose that goes on the throttle body
aim the intake above the battery and your fine\
remove all the intake stuff too.
only thing is where the intake used to be, is this big nothing
but i like the look better.
very nice looking intake
mine is in blue
i'll try to post pics. sometime when i can borrow a digital camera.
Old Nov 6, 2002 | 12:56 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
I'd like to get rid of the rubber flex piece too Dale..it's just...fugly. problem is...the throttle body fitting is oval..*** knows why...so you have to get some sort of fitting that goes from just the right size oval over to a circular thing..although we could probably hack the rubber flex part for that. I was hoping to get a hold of a nice piece of stainless steel for the intake but I can't find a place that cuts it to size..they all sell it as a whole piece, which is pretty expensive.. Maybe if I find another use for it...
Old Nov 6, 2002 | 04:42 PM
Camar_Hunter_c's Avatar
that has to be one of the bristest engine bays I have ever seen!
Old Nov 6, 2002 | 10:08 PM
Nixon1's Avatar
It's definitely....fluorescent!
Old Nov 6, 2002 | 11:34 PM
devianb's Avatar
Don't let the picture fool you, my engine bay isn't as bright as it looks in the pic. It was overcast that day and I had to use a little bit of light. I know it is colorful, but it sure makes working in the engine bay fun.
Old Nov 6, 2002 | 11:37 PM
devianb's Avatar
If you take a 3" aluminum pipe and somehow bend the ends into an oval shape, it is almost a perfect fit. That oval throttle body is the very reason why I still have my stock rubber intake hose. I would like to make it as short as possible.
Old Nov 7, 2002 | 07:02 PM
Nixon1's Avatar
Completely agree with ya....
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
TexasFormula
Sep 30, 2015 06:36 PM
aaron7
Sep 30, 2015 09:15 AM
92projectcamaro
Sep 29, 2015 07:07 PM
