fuel pressure regulator
Old Nov 8, 2002 | 10:58 AM
Adidas3k's Avatar
can i put one on my 3.1L?
where can i find one?
how much do they cost?
where do i put it?
Old Nov 8, 2002 | 11:34 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
3.1 has one on the fuel rail
Dealer for a stock replacement, Summit or others for an adjustable one. V-6s use the same FPR as V-8s
No clue
Same place your old one is
Old Nov 8, 2002 | 11:45 AM
Adidas3k's Avatar
thnx bro
Old Nov 8, 2002 | 11:57 AM
Camar_Hunter_c's Avatar
typically $150+
Old Nov 8, 2002 | 04:54 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
'Course, Summit won't verify that it'll work on the v6; their tech sheets only mention v8's, but the regulator will work. Look for one mentioning the camaro/firebird 305/350 TPI motor. Your stock fuel pressure regulator is on top of your fuel rail, underneath your "spider-like" upper-plenum on top of the engine.
Cost is about $80 from Summit. 'Fact, the BBK one is $60. Go to http://www.summitracing.com , click on "browse online catalog" (on left top), click on "air and fuel delivery" section, click on "fuel pressure regulators". Then go thru the list. Make sure to buy a fuel pressure gauge (for fuel injected engines, gauge handles the higher pressure of fuel injection) for $30 so you can tune the regulator.
But.... if you don't have serious mods (cam, headwork, headers), don't bother with an adjustable fuel pressure regulator. Work on other mods first. If your engine doesn't need the extra fuel, you won't benefit from it...
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
