TTA swap
Old Nov 9, 2002 | 06:33 PM
Adidas3k's Avatar
TTA swap
if i were to find the engine out of a TTA, could i swap it in to my 90 f-bird? would it be a direct fit since its a V6? or would i be better off trying to swap a 5.0 or 5.7
Old Nov 9, 2002 | 09:11 PM
Ovrclck350's Avatar
You'd have to have transmission, crossmember, wiring harness, motor mounts, and some other lil goodies.
Old Nov 10, 2002 | 02:06 AM
zer0321's Avatar
Old Nov 10, 2002 | 08:48 AM
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
You MIGHT have to change the front springs, the buick 3.8 probably weighs more than the 3.1, its a pretty beefy block. You also might have to change your tach, My V8 didnt' work which was to be expected but I know someone else that did the swap and a V6 one didn't work either, mabye its because the motor is SFI
The motor is a direct fit, it uses the same holes for the V6 on the crossmember. Now, being that you have a 60* V6 now the 700r4 will not bolt up. You either A)Have to find a 90* 700r4 thats built up pretty well and get the TCI adapater plate -OR- B)Bite the bullet and do the 200-4r swap. Here is where you have a few options. You COULD try to find a TTA crossmember that would allow you to run the stock torque arm for now, or you could just order spohn's torque arm and crossmember package, you'll still either need a TTA driveshaft or have one made up.
It's going to be tough to find an orginal TTA motor, a few of us have been lucky enough to fine one, a GN one will work fine, you'll have to ditch the AC with the GN heads, hell I ditched the AC with the TTA motor :sillylol:
The GN motor is a bit different, the heads are different, which in stock form don't flow as well as the TTA heads, BUT there is more "meat" to the GN heads, you can do a better port job on them. The GN intercooler scoop will also not work from what I'm told, it sits too low for the fbody car, it will scrape. I want to grab a GN scoop so I can look at the differences myself.
If you're really serious about this there are a couple of sites to go to..
turbobuick.com
turbobuicks.com
gnttype.org
Oh yeah, if you get a GN engine you're gonna need to spend the $$ on a TTA wiring harness which is CASHOLA!!!
Also, to add..if you went the GN motor route you could use the GN headers and crossover pipe but you would need a custom downpipe made.
lee01
Apr 9, 2016 01:56 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Firebird sweden
Aug 16, 2015 05:02 PM
