Clicking Sound on Acceleration...
Old Nov 12, 2002 | 10:33 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
Clicking Sound
This is on the '88 Camaro in the sig...
I've noticed that I can hear a clicking sound on the inside of of my car that varies with engine speed, and it's more audiable the more gas I give it. It's just a slight tapping/ticking sort of sound. The only other place I've heard this before was on my brother's Jeep, and it was even louder there.
I almost wonder if it's comming from the intake since it gets louder the as I step on the gas more (so the throttle plate opens allowing more sound to get through).
Any ideas as to what this might be?
Old Nov 12, 2002 | 11:02 PM
Project92's Avatar
Okay, a few quick questions. When was the last time you gave your car a tune up? How many miles are on it? Dit it start all of a sudden, or has it been a persistant problem that's just getting louder?
Craig C.
Old Nov 12, 2002 | 11:33 PM
sancho's Avatar
The car has had a "tune up" within the past year. By that, I mean that I've done the following (off the top of my head):
- new plugs
- new wires
- new rotor
- coolant change
- oil/filter change
- transmission fluid/filter change
- timing set to spec (as close as I could get it, given that the timing chain is probably stretched)
There are actually probably more things, but I do try to keep the car pretty-well maintained.
It has ~125,000 miles on it.
I don't think that's it's started all of the sudden, but then again, I'm not sure. Probably I only just started noticing it recently. What I have noticed for as long as I can remember is that I hear a similar and constant ticking at idle in the engine bay (i.e. when the hood is open and I'm watching it idle). To me, that one really sounds like a loose rocker arm. Or I suppose it could be comming from the exhaust; there is a bolt missing in the passenger's exhaust manifold, closest to the firewall. As to what it would more likely be, I don't know.
I'm just trying to avoid pulling off valve covers if I don't have to...
Old Nov 13, 2002 | 08:19 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Our injectors make a ticking sound normally so that could be it. If you want to find out if its a rocker arm or other problem, take a really long socket extension, put one end on the area that's making the noise, and hold the other end to your ear.
Old Nov 13, 2002 | 10:59 AM
devianb's Avatar
I have a ticking sound under my hood, but that is from the ACCEL 300+ MS box. Since my exhaust is loud I can't hear it.
Old Nov 13, 2002 | 12:04 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
ticking sounds are usually exhaust leaks or valve train noise, loose lifter/rocker.
Lbibb
May 5, 2016 12:00 AM
wanext
Oct 6, 2015 12:18 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
