Why am I grinding
Old Nov 13, 2002 | 05:03 PM
wrstdude's Avatar
Car: '04 Rubicon
Why am I grinding
Hey fellow third gen peeps,
I've got a 92 RS 5-speed-and she is starting to worry me. When I start her up, I'm getting a serious grinding sound possibly from the tranny. I can feel it all the way through the stick. It feels like when you're shifting and you grind it. It happens when it starts and even while I'm driving-no I'm not a new stick driver-I've not grinding the gears-but it feels like its doing it on its own....I don't know-any help is appreciated.
Old Nov 13, 2002 | 05:17 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Sounds like the T-5's going to breathe its last
Old Nov 13, 2002 | 05:51 PM
vortechLT1's Avatar
Re: Why am I grinding
tranny couldnt grind on start up unless the clutch is not disengaging all the way.
does it slip at all? if no it sounds like the clutch master or slave cyl. may be bad, check the master for air bubbles or signs of corrosion also check the color of the fluid inside it should look like new brake fluid. that would also explain the grinding feel and sound when driving
Old Nov 13, 2002 | 06:38 PM
biff85ta's Avatar
Car: 04 Vette
you might have a throw out bearing going out
Old Nov 13, 2002 | 07:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
throw out bearing and or someone put regular gear lub in the tranny and in these colder months or make some noise untill it gets warmed up.
T-5 in the book and ask the dealer and they will say to use atf auto trans flud in it. yep aft
but guy at junk yard told me to run straight 30w oil to make it last allot longer , only thingi s you gotta let it warm up a bit when it cold. but I dont hear any noise from that but maybe if thee is 89-90 or straight 90 in there it might make some noise.
Old Nov 21, 2002 | 11:43 AM
vortechLT1's Avatar
I got 85-90 in my 4sp, doesnt make any noise
Jorlain
Oct 8, 2015 01:57 AM
hdis2002
Sep 8, 2015 02:52 PM
solocus
Sep 2, 2015 12:14 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
hokis
Aug 9, 2015 03:57 PM
