Need part number fast!!!!
Old Nov 13, 2002 | 06:39 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Need p/n for oil filter adaptor gasket. damn thing is leaking like there is no tomarrow
I know you west coast peeps still have your dealerships open
Old Nov 13, 2002 | 10:45 PM
KED85's Avatar
Please explain better.
GASKET FOR THE OIL FILTER HOUSING?
THE O RING FOR THE BOLT THAT GOES THRU THE OIL FILTER HOUSING holding that item to the engine block?
This area of the project is still seeking refinement from us swappers.
I hope I solved my oil leaks from there on my 3.4 Blazer project.
This time...
I left oil filter housing alone & I just added a fitting to reuse my original S-10 Blazer oil sensor.
ON MY FIREBIRD oil filter housing....
I've obtained a new o ring for the bolt thru the housing & I have a new gasket for when the oil housing is removed to replace that gasket.
I believe you are referring to this problem?
Old Nov 13, 2002 | 11:03 PM
Engine: 5.7 / 7.4
yup, that's it. The item that the oil filter screws into. I had to keep the 2.8 one, as it ahd both the oil pressure sender & the fp cut off switch. have about 1/2-3/4 qt of valvoline on the garage floor.
Old Nov 13, 2002 | 11:24 PM
KED85's Avatar
Were my answers helpful then?
O Ring was a parts store item ($.25!)
Housing Gasket came in my Fel Pro gasket kit I had purchased for my swap. I also got that at GM too.
YOU SHOULD HAVE SPARE OIL FILTER HOUSING BOLT!!!
Find that, get new o ring & new filter housing gasket & have fun.
As I am/will be on my Firebird again...... shortly.
Yep leaking there, too!
Pissed at myself for not knowing better.
I was hoping I offered my solutions earlier for oil housing leakage but.....
Easy item to locate at a GM dealer.
The paperwork I got from CaliCamaro is minus the parts numbers, YET it cost me about $1.50 from a GM dealer.
Old Nov 14, 2002 | 08:53 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
I used a small (but adequate) amount of Black RTV on the housing when I resealed the one on my 83...
Old Nov 14, 2002 | 11:37 AM
Engine: 5.7 / 7.4
Oil filter adapter gasket p/n: 12337894
$2.46, $2.61 after tax at dealership
$0.82 @ gmpartsdirect.com, put you have to order 10 $17 after shipping
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
IrocZ'85
Aug 17, 2015 06:24 PM
armybyrd
Aug 10, 2015 09:23 PM
