Exhaust Pipe Diameter
Old Nov 15, 2002 | 02:32 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I just had the pipe from the end of the cat and everything back replaced. Now the pipe in a diagram I was looking at coming into the muffler should be 2.25" then 2" dual out the passengers side. Well the muffler I have now is 2.5" in and dual 2.5" out. Would this effect me any for the worse with a V6?
Old Nov 15, 2002 | 02:56 PM
devianb's Avatar
Shouldn't think so.
Old Nov 15, 2002 | 04:38 PM
JoshDT91's Avatar
Engine: 2.8L V6
Yeah I was thinking it wasn't too large. At most it made the tail pipes 0.5" larger and considering most of the larger diameter is at the end of the system I guess it would not matter.
Old Nov 15, 2002 | 09:05 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
2.5 is just perfect. If only your ENTIRE system was 2.5 inches! I wouldn't go higher than that though...3 in. robs too much torque and low end and messes with the power curves.
Old Nov 16, 2002 | 02:27 AM
gecko's Avatar
where is this "back pressure" force applied to ?
the vavles ?
from the converter forward ?
from the muffler to the tips ?
Old Nov 16, 2002 | 02:35 AM
JoshDT91's Avatar
Engine: 2.8L V6
I always thought it was applied to the cylinder where combustion occurs but I wouldn't really know, that's just a guess.
Old Nov 16, 2002 | 10:24 AM
KED85's Avatar
Simply put
Back Pressure
Torque
Push ya back in the Seat Stuff!
2 1/2" in & Out CC
2 1/2" Intermeidate Pipe
2 1/2" in to two 2 1/2" out muffler tips to bumper.
Works just great!
EVEN BETTER!
Have remade your "Y" pipe. Make it a smoother connection & ya easily gain 5 HP & smoother runner engine.
Open hood look down engine passenger side see why.
Old Nov 16, 2002 | 02:22 PM
JoshDT91's Avatar
Engine: 2.8L V6
Yeah I've seen that crummy Y pipe. It's like a 90 degree connection and I don't think that can flow well at all. If only I had tons of money then I could consider messing with the Y-pipe and cat.
Old Nov 16, 2002 | 03:53 PM
KED85's Avatar
Check, IT could be very inexpensive.
GAIN BACK REAL FEEL HP!
Fronzizzle
Feb 9, 2017 09:31 AM
bamaboy0323
Sep 12, 2015 07:14 PM
iroczz89
Sep 12, 2015 04:55 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
