tire size
Old Nov 24, 2002 | 05:52 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
tire size
im buying a pair of BFG Radial T/A 265/50 / 15 for my stock 15x7 Rally sport rims on the rear only
will it fit on the rim?
will it rub at all?
do i need to make suspension changes or can i leave it?
and 205 /50/ 15 for the same type of rim in the front?
Old Nov 24, 2002 | 08:08 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
the bigest tires on an 85 Firebird were P245/50VR16. I think that was the biggest used that wouldn't rub. Also, go to maybe www.tirerack.com , I belive they might have a table to compare tire size, to make sure sure your new tires are just about as tall as the ones you're replacing to minimalize speedo discrepency.
Old Nov 24, 2002 | 11:54 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
friend used to run 255's on the back of his T/A. Those were mounted on 16x8 rims also. I'm running 235's out back right now, and i can't find a 245 that's in a 15 in size...so it looks like the 235s will be on there for a while.
Old Nov 25, 2002 | 03:40 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
anyone else got any opinions?
Old Nov 25, 2002 | 04:42 PM
biff85ta's Avatar
Car: 04 Vette
245 60 15`s maybe but I 235 60 is largest that will fit on a 15 without any problems and they used those from the fact on some t/a`s
Old Nov 27, 2002 | 12:02 AM
SlowCamaro88SC's Avatar
P235/60VR15 was an optional size on '87 z28's.
only 15 were sold that way.
the 50 series won't fit the rear w/ 265's. it's been tried. not on a 7" wheel.
and the 205/50 up front is way too short and will look ghey.
short sidewalls don't look good unless you're lowered. esp. w/ 15" wheels
Old Nov 27, 2002 | 03:31 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
ok
keep em comin!
i still want more different ppl's ideas on the tire sizes i want..
im also Leaning towards a 225 50 on the rear any thoughts on if it fits the rim?
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
