IAC Valve
Old Dec 30, 2002 | 01:37 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
IAC Valve
This is the first, and probably the last, one sentence post you will ever see me make.......so, the IAC valve, where is it and how do I remove, and clean it?
Old Dec 30, 2002 | 02:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
PAssenger side of the TB. Its generally black. Will have a 3 wire harness on it. Held in by torx bits. Unplug it, carfully remove it. Spray carb cleaner on tip. Rub carbon off w/o pushing or spinning tip. Then spray carb cleaner in the hole it goes in, take pinky and rag, clean it out. STick back in, carefully screw down, plug up.
Old Dec 31, 2002 | 12:40 PM
Nixon1's Avatar
Is it sticking vertically or horizontally into the TB? I think I see what you're talking about..mine is all just painted since I was too lazy to REMOVE my plenum when I painted it.
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
