89 Knock Sensor?
Old Jan 4, 2003 | 09:34 PM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
89 Knock Sensor?
I found this connector loose in the back of the engine bay. I'm thinking it's the knock sensor, but I didn't see one in the wiring diagram in the chilton's (not that that's a first). It's just a single green wire. I just replaced the ignition module, and now when you hit the throttle under load, it sounds like it's knocking, no matter where you set the timing. I thought that the knock sensor was on the passenger side mounted to the head, but I didn't see it there. Thanks, Joe
Old Jan 4, 2003 | 10:10 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Looks like the knock sensor wire to me.
Mine is right around the starter, down low, pass side.
If you need to replace it, go with one for a 96 corvette (LT4) they are supp to be better and give less fasle readings.
Old Jan 4, 2003 | 10:42 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i don't think they put knock sensor in the 2.8. i thought that was new to the 3.1's.
Old Jan 5, 2003 | 01:23 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
That's what I thought too, but the parts store showed one for the engine.
Thanks for the help Dale. Did you have to get under the car to get to it, or is it accessible from the top? Also, is there some trick to getting the connector off?
Old Jan 5, 2003 | 08:45 AM
Dale's Avatar
Engine: 350 S-TPI
It would be easier from under the car. Like you were fixing to pull the starter. To get it off, you squezie the outter edges that buldge. CAREFULLY, it is brittle now and might crack. To get the acutaul sensor out, you crank it out, but make sure car is cold because anti-freeze will come out when its out.
Any engine that runs fuel injection has a knock sensor.
Old Jan 5, 2003 | 10:27 PM
WaynesRS's Avatar
This maybe a stupid question , but what are the signs of a bad knock sensor ? Does your engine just knock under load ?
Old Jan 7, 2003 | 10:20 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
My car has one and it's mounted in the back of the pass. side cylider head.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
