Dual air intake question
Old Jan 5, 2003 | 11:10 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
A friend got me this dual air intake system from an older camaro.I am going to put it on my 91 RS V6.Will I notice any difference if I put this on and would it be worth it?
Old Jan 5, 2003 | 12:13 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
well if you really care about the gains, run a true cold air/ ram air dual intake.
if the filter is exposed under the hood, even with a shield, i dont know how much it helps for it to just be sucking twice as much hot a$$ air.
Old Jan 5, 2003 | 12:59 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Dual air intake question
Yes, the gains are significant. Just be sure to extend the IAT sensor wires to reach the new location within the dual (or Y) air cleaner.
To fill in the MAF location (you'll have a gap between the air cleaner outlet and the rubber bellows) I first used a soup can with some electrical tape on the ends for fit. I've since switched to a piece of PVC (needed to machine it also). Of course a MAF will also work for a filler.
Can see Nixon1's recent post about the 'Guess the mystery mod' for what I found.
RBob.
Old Jan 5, 2003 | 07:29 PM
ken3983's Avatar
I got it today.Looks like it came out of a 86 2.8 v6.I will have to extend the wired for the IAT sensor.No biggie.There is a MAF tube there,so that will fill in the gap between the Y-shape ducts and the rubber snorkel going to the throtle body.I am going to try to turn the MAF tube around to see if I can make the tube coming from the crankcase cover line up with the one on the MAF tube.If it is going to be a hassle,I'll plug it up and get a breather to replace the tube coming from the crankcase valve cover.Thanks for the input guys.
Old Jan 5, 2003 | 08:16 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You can see a pic of how I did mine with the v8 dual intake on my website. copy clip the link in my siggy.
Old Jan 5, 2003 | 09:08 PM
ionicswing's Avatar
would the gains of the dual snorkel be the same as just biulding a custum one with pvc pipe???
Old Jan 5, 2003 | 09:28 PM
Dale's Avatar
Engine: 350 S-TPI
It seemed about same to me. tone did get a "Tad" deeper.
Noone else had both set ups before, so I had half the v8 intake, so I got other half and installed so it would be easier for mrs to check/change filters.
Plus, this is lighter then my CAI I made.
1992 Trans Am
May 10, 2023 07:19 PM
PestilenceIV
Aug 20, 2015 02:33 AM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
