3.4 to 3.8
Old Jan 20, 2003 | 06:35 PM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
3.4 to 3.8
My brother is thinking about swapping a 3.8 into his 93 camaro in place of his 3.4, I have so far told him his best bet is to find a wrecked 3.8 car but he is concerned about cost and time. About how much should this swap cost in time and money, ballpark figures. thanx in advance.
Old Jan 20, 2003 | 06:51 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
swap
Whereas I have no clue about the cost of a 3.8L, I'm curious as to why he doesn't just go to an LT1? It probably wouldn't cost much more.
Old Jan 20, 2003 | 07:11 PM
Camar_Hunter_c's Avatar
In all honesty, a LT1 would probly be cheaper, and require all the same parts.
Again the 2.8/3.1/3.4 's are a 60* block.
The 3.8/4.3/small blocks/big blocks are 90* blocks. So to swap from a 3.4 to a 3.8, is just about worthless. as swapping to the engine in question will require everything that will be needed to go Small block.
As far as finding a seller, you can check Ebay, www.car-part.com , local yards. Though you will probly want to find a wrecked V8 version so you will not be dimed to death. You then sell the scraps to a yard for a small return.
Old Jan 20, 2003 | 09:02 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you wi;; probobly have better luck at Firebird/CamaroV6.com they're more 4th gen biased, and will have more of a knowledge base to tap.
Old Jan 20, 2003 | 09:30 PM
KED85's Avatar
3.4->3.8 UNLESS IT'S A HACK JOB,
Find another 3.8/V-8 platform to work forward from.
I've seen to many wrecks of 4th gens lately.
TO Easy to find the right stuff.
Old Jan 21, 2003 | 05:39 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
you are so right, just seen a 4th gen not that long ago with the rear end about 1/4 mile down the road ahead of him. he got on the eway hot, lost it into the wall and the rear end left him behind.
Im sure for a second it was funny.
Old Jan 21, 2003 | 06:44 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Neighbor might have a 98 3.8l bird for sale soon. Has 80k on it, great shape except for the tires.
BRAND NEW BREAKS!!!!
Can't afford issurnace while attending college
AussiePr0nCar
Mar 6, 2020 04:04 PM
neilb
Oct 4, 2018 12:36 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
92projectcamaro
Sep 29, 2015 07:07 PM
