need info !
Old Jan 22, 2003 | 12:30 PM
kevinragman's Avatar
need info !
Please can anyone help. I need the correct fireing order for my v6 camaro. In the manual it says 1-2-3-4-5-6, is this correct? If any one has a diagram of this I will be a happy chappy again. Ikneed to get the car running now. Please help
Old Jan 22, 2003 | 12:52 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
The firing order you have is coorect
1-2-3-4-5-6
It starts with passenger front.
1-3-5 right bank,
2-4-6 left bank.
Old Jan 22, 2003 | 09:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yup, it uncanningly f*rdish
Old Jan 23, 2003 | 08:09 AM
Xceleratemaro's Avatar
wrong when i had to re wire my 90 3.1 the motors #s are left bank starting from the front 1,3,5, and the right bank are 2,4,6 i had to get my info from alldata becouse i wired them up wrong the first time thats the correct order
Old Jan 23, 2003 | 09:54 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
no...joe is right...because the passenger side is considered the right bank because of when you're sitting in the car...thats howyou usual distinguish between both sides...but i can see how you would say it backwards...so in a way your both right depending upon how you look at it...
Old Jan 23, 2003 | 12:25 PM
well then hes right sorry im not good with lengo
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
